nginx配置laravel
风吹稻花香 发表于 2021/06/05 00:58:12 2021/06/05
【摘要】 异常日志:   sudo gedit /var/log/nginx/error.log   sudo service nginx restart   sudo gedit /etc/nginx/sites-available/default   4.2配置 server {    &nb...
异常日志:
4.2配置
server {
    listen 80 default_server;
    listen [::]:80 default_server ipv6only=on;
    # 设定网站根目录
    root /var/www/laravel/public;
    # 网站默认首页
    index index.php index.html index.htm;
    # 服务器名称,server_domain_or_IP 请替换为自己设置的名称或者 IP 地址
    server_name localhost;
    # 修改为 Laravel 转发规则
    location / {
        try_files $uri $uri/ /index.php?$query_string;
    # PHP 支持
    location ~ \.php$ {
        try_files $uri /index.php =404;
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass unix:/var/run/php5-fpm.sock;
        fastcgi_index index.php;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
        include fastcgi_params;
5.0:
server {
    root /var/www/laravel/learnlaravel5/public;
    index index.html index.htm index.php;
    # Make site accessible from http://localhost/
    location / {
    # Pass all .php files onto a php-fpm/php-fcgi server.
    location ~ [^/]\.php(/|$) {
        fastcgi_split_path_info ^(.+?\.php)(/.*)$;
        if (!-f $document_root$fastcgi_script_name) {
            return 404;
原文链接:blog.csdn.net/jacke121/article/details/55548934
