opencv 计时 帧率
风吹稻花香 发表于 2021/06/05 00:00:31 2021/06/05
【摘要】 C++版的getTickFrequency返回的是每秒钟的tick数 C版的cvGetTickFrequency返回的是每微妙的tick数 double t = (double)cvGetTickCount(); //  算法过程 t = (double)cvGetTickCount() - t; printf( "run time = %gms\...
//  算法过程
printf( "run time = %gms\n", t/(cvGetTickFrequency()*1000) );
这//opencv 中如何进行程序的计时呢?
 int64 tStart = 0;
 int64 tDuration = 0;
   tStart = getTickCount();
 tDuration = getTickCount() - tStart;
 double fps = static_cast<double>(getTickFrequency() / tDuration);
  printf("fps:%f\n",fps);
计时函数
1. 纯C 高精度(100ns)测量慢
[cpp]  view plain  copy
  1. #include <Windows.h>
  2. #include <stdio.h>
  3. int timer1_test()
  4. {
  5.     LARGE_INTEGER start;
  6.     LARGE_INTEGER end ;
  7.     LARGE_INTEGER frequency;
  8.     int i = 0;
  9.
  10.     if (!QueryPerformanceFrequency(&frequency))
  11.     {
  12.         return -1;
  13.     }
  14.
  15.     QueryPerformanceCounter(&start); //开始计时
  16.
  17. //     for (int i = 0; i < 100000; ++i)
  18. //     {
  19. //         ;// 用循环来测试计时
  20. //     }
  21.     Sleep(1);
  22.     QueryPerformanceCounter(&end); //结束计时
  23.
  24.     printf("main cost:%f\n", (double)(end.QuadPart - start.QuadPart) / (double)frequency.QuadPart); //打印for循环执行时间
  25.
  26.     getchar();
  27.     return 0;
  28. }
2.纯C 低精度(1ms)测量快
  1. #include <stdio.h>
  2. #include <time.h>
  3.
  4. void timer2_test()
  5. {
  6.     clock_t start,end;
  7.     start=clock();
  8.     Sleep(1000);
  9.     end=clock();
  10.     double duration = (double)(end - start);
     cout << "--> time: " << duration << " s" << endl;
     printf("time  : %f  ms \n",duration/1000);
  11. }
3.C++  OpenCV测试 高精度 view p copy
  1. #include"opencv.hpp"
  2.
  3. void timer3_test()
  4. {
  5.     int64 start=0,end=0;
  6.     start = getTickCount();
  7.     Sleep(1000);
  8.     end = getTickCount();
  9.     cout << "The differences: " << 1000.0*(end - start)/getTickFrequency()<<" ms"<< endl;
  10. }
这个是在多线程下比较精确的
#include <time.h>
struct timespec time1={0,0};
struct timespec time2={0,0};
int main()
 clock_gettime(CLOCK_REALTIME,&time1);
 sRect result = tracker.update( frame);
 clock_gettime(CLOCK_REALTIME,&time2);
 sum_time += (time2.tv_sec-time1.tv_sec)*1000+(time2.tv_nsec-time1.tv_nsec)/1000000 ;
 printf("time  : %d  ms \n", (time2.tv_sec-time1.tv_sec)*1000+(time2.tv_nsec-time1.tv_nsec)/1000000);
 return 0;
原文链接:blog.csdn.net/jacke121/article/details/60138923
