利用FreeImage将gif图像转为opencv中的Mat
风吹稻花香 发表于 2021/06/05 00:24:42 2021/06/05
【摘要】 原文:http://www.cnblogs.com/monkeyhey/p/3927857.html 网上有将gif转为iplimg的版本,只是用惯了C++的接口,所以就写了个转Mat的版本,代码比较简单 一、读文件 1 int MatFun::gif2Mat(char* data, size_t dataSize, vector<Mat...
一、读文件
复制代码
 1 int MatFun::gif2Mat(char* data, size_t dataSize, vector<Mat>& gifImgs, Mat& singleImg)
 2  {
 3 /* initialise
 4  ->open memory
 5  ->getImageType
 6  ->load bitmaps
 7  ->bitmaps to Mat
 8  ->free all resource
 9 */
10 // condition1: data is not null
11 if (NULL == data || dataSize == 0)
12 return -1;
13  FreeImage_Initialise();
14 FIMEMORY* memory = FreeImage_OpenMemory((BYTE*)data, dataSize);
15 if (NULL==memory)
16  {
17 FreeImage_DeInitialise();   //condition 2: memory is not null
18  }
19
20 FREE_IMAGE_FORMAT fif = FreeImage_GetFileTypeFromMemory(memory);
21 if (FIF_UNKNOWN == fif) //condition 3: type of image should be know
22  {
23 fprintf(stderr, "unknown type of image");
24 if (NULL != memory) FreeImage_CloseMemory(memory);
25  FreeImage_DeInitialise();
26 return -1;
27  }
28 else if (FIF_GIF != fif)  //condition 4: type of image should be GIF
29  {
30 if (NULL != memory) FreeImage_CloseMemory(memory);
31  FreeImage_DeInitialise();
32 return 0;
33  }
34
35 FIMULTIBITMAP * fiBmp = FreeImage_LoadMultiBitmapFromMemory(fif, memory, GIF_DEFAULT);
36 if (NULL==fiBmp)
37  {
38 if (NULL != memory) FreeImage_CloseMemory(memory);   //condition 5: bitmaps is not null
39  FreeImage_DeInitialise();
40 return -1;
41  }
42
43 int num = FreeImage_GetPageCount(fiBmp);
44
45 for (int i = 0; i < num; i++)
46  {
47 if (i==0 || i==2)
48  {
49 FIBITMAP *mfibmp = FreeImage_LockPage(fiBmp, i);
50 if (mfibmp) 51  {
52 Mat dst = bitMap2Mat(mfibmp, fif);
53 FreeImage_UnlockPage(fiBmp, mfibmp, false);
54 if (dst.empty())
55  {
56 if (NULL != memory) FreeImage_CloseMemory(memory);
57 if (NULL != fiBmp) FreeImage_CloseMultiBitmap(fiBmp, GIF_DEFAULT);
58  FreeImage_DeInitialise();
59 return -1;
60  }
61  gifImgs.push_back(dst);
62  dst.release();
63  }
64  }
65  }
66
67 if (NULL != memory)
68  FreeImage_CloseMemory(memory);
69 if (NULL != fiBmp)
70  FreeImage_CloseMultiBitmap(fiBmp);
71  FreeImage_DeInitialise();
72
73 return 0;
74 }
复制代码
这部分其实功能很简单,代码里面大部分都是检查,实际执行就初始化、打开内存、内存中读bitmap这几步。
二、gif转Mat
复制代码
 Mat MatFun::bitMap2Mat(FIBITMAP* fiBmp, const FREE_IMAGE_FORMAT &fif) { if (NULL == fiBmp || FIF_GIF != fif) return Mat(); int width = FreeImage_GetWidth(fiBmp); int height = FreeImage_GetHeight(fiBmp); BYTE intensity; BYTE* pIntensity = &intensity; if(FreeImage_GetBPP(fiBmp) !=8) fiBmp = FreeImage_ConvertTo8Bits(fiBmp); //必须转化为8bit RGBQUAD* pixels = new RGBQUAD; pixels = FreeImage_GetPalette(fiBmp); Mat img=Mat::zeros(height, width, CV_8UC3); uchar* p; for (int i = 0; i < height; i++) { p = img.ptr<uchar>(i); for (int j = 0; j < width; j++) { FreeImage_GetPixelIndex(fiBmp, j, i, pIntensity); p[3 * j] = pixels[intensity].rgbBlue; p[3 * j + 1] = pixels[intensity].rgbGreen; p[3 * j + 2] = pixels[intensity].rgbRed; } } return img; }
复制代码
具体的将byte像素转化为mat里面的像素值即可,注意rgb图像的Mat里是一个像素包含三通道的值,知道这点,代码就很好理解了。
  1. #include <FreeImage.h>
  2. #include <opencv2\opencv.hpp>
  3. using namespace cv;
  4. void FI2MAT(FIBITMAP* src, Mat& dst)
  5. {
  6. //FIT_BITMAP //standard image : 1 - , 4 - , 8 - , 16 - , 24 - , 32 - bit
  7. //FIT_UINT16 //array of unsigned short : unsigned 16 - bit
  8. //FIT_INT16 //array of short : signed 16 - bit
  9. //FIT_UINT32 //array of unsigned long : unsigned 32 - bit
  10. //FIT_INT32 //array of long : signed 32 - bit
  11. //FIT_FLOAT //array of float : 32 - bit IEEE floating point
  12. //FIT_DOUBLE //array of double : 64 - bit IEEE floating point
  13. //FIT_COMPLEX //array of FICOMPLEX : 2 x 64 - bit IEEE floating point
  14. //FIT_RGB16 //48 - bit RGB image : 3 x 16 - bit
  15. //FIT_RGBA16 //64 - bit RGBA image : 4 x 16 - bit
  16. //FIT_RGBF //96 - bit RGB float image : 3 x 32 - bit IEEE floating point
  17. //FIT_RGBAF //128 - bit RGBA float image : 4 x 32 - bit IEEE floating point
  18. int bpp = FreeImage_GetBPP(src);
  19. FREE_IMAGE_TYPE fit = FreeImage_GetImageType(src);
  20. int cv_type = -1;
  21. int cv_cvt = -1;
  22. switch (fit)
  23. {
  24. case FIT_UINT16: cv_type = DataType<ushort>::type; break;
  25. case FIT_INT16: cv_type = DataType<short>::type; break;
  26. case FIT_UINT32: cv_type = DataType<unsigned>::type; break;
  27. case FIT_INT32: cv_type = DataType<int>::type; break;
  28. case FIT_FLOAT: cv_type = DataType<float>::type; break;
  29. case FIT_DOUBLE: cv_type = DataType<double>::type; break;
  30. case FIT_COMPLEX: cv_type = DataType<Complex<double>>::type; break;
  31. case FIT_RGB16: cv_type = DataType<Vec<ushort, 3>>::type; cv_cvt = COLOR_RGB2BGR; break;
  32. case FIT_RGBA16: cv_type = DataType<Vec<ushort, 4>>::type; cv_cvt = COLOR_RGBA2BGRA; break;
  33. case FIT_RGBF: cv_type = DataType<Vec<float, 3>>::type; cv_cvt = COLOR_RGB2BGR; break;
  34. case FIT_RGBAF: cv_type = DataType<Vec<float, 4>>::type; cv_cvt = COLOR_RGBA2BGRA; break;
  35. case FIT_BITMAP:
  36. switch (bpp) {
  37. case 8: cv_type = DataType<Vec<uchar, 1>>::type; break;
  38. case 16: cv_type = DataType<Vec<uchar, 2>>::type; break;
  39. case 24: cv_type = DataType<Vec<uchar, 3>>::type; break;
  40. case 32: cv_type = DataType<Vec<uchar, 4>>::type; break;
  41. default:
  42. // 1, 4 // Unsupported natively
  43. cv_type = -1;
  44. }
  45. break;
  46. default:
  47. // FIT_UNKNOWN // unknown type
  48. dst = Mat(); // return empty Mat
  49. return;
  50. }
  51. int width = FreeImage_GetWidth(src);
  52. int height = FreeImage_GetHeight(src);
  53. int step = FreeImage_GetPitch(src);
  54. if (cv_type >= 0) {
  55. dst = Mat(height, width, cv_type, FreeImage_GetBits(src), step);
  56. if (cv_cvt > 0)
  57. {
  58. cvtColor(dst, dst, cv_cvt);
  59. }
  60. }
  61. else {
  62. vector<uchar> lut;
  63. int n = pow(2, bpp);
  64. for (int i = 0; i < n; ++i)
  65. {
  66. lut.push_back(static_cast<uchar>((255 / (n - 1))*i));
  67. }
  68. FIBITMAP* palletized = FreeImage_ConvertTo8Bits(src);
  69. BYTE* data = FreeImage_GetBits(src);
  70. for (int r = 0; r < height; ++r) {
  71. for (int c = 0; c < width; ++c) {
  72. dst.at<uchar>(r, c) = saturate_cast<uchar>(lut[data[r*step + c]]);
  73. }
  74. }
  75. }
  76. flip(dst, dst, 0);
  77. }
  78. int main()
  79. {
  80. FreeImage_Initialise();
  81. FREE_IMAGE_FORMAT format = FreeImage_GetFileType("path_to_image", 0);
  82. FIBITMAP* fi_image = FreeImage_Load(format, "path_to_image");
  83. Mat cv_img;
  84. FI2MAT(fi_image, cv_img);
  85. return 0;
  86. }
原文链接:blog.csdn.net/jacke121/article/details/60569972
