jni和java之间字符串的转换
风吹稻花香 发表于 2021/06/04 23:18:14 2021/06/04
【摘要】  jni和java之间字符串的转换方法。   C的实现:   JNIEXPORT jstring JNICALL Java_Android123_CwjC (JNIEnv *env, jobject obj, jstring string)   {    char szBuffer[255];    return (*env)->NewS...
 jni和java之间字符串的转换方法。
  C的实现:
   char szBuffer[255];
   return (*env)->NewStringUTF(env, szBuffer);
  C++的实现:
  JNIEXPORT jstring JNICALL Java_Android123_CwjCpp (JNIEnv *env, jobject obj, jstring string)
  const char *strUTF = env->GetStringUTFChars(string, 0);
  char szBuffer[255];
  strcpy(szBuffer, strUTF);
  env->ReleaseStringUTFChars(string, strUTF);
  return env->NewStringUTF(szBuffer);
java中string与byte[]的转换
1.string 转 byte[]
byte[] midbytes=isoString.getBytes("UTF8");
//为UTF8编码
byte[] isoret = srt2.getBytes("ISO-8859-1");
//为ISO-8859-1编码
其中ISO-8859-1为单字节的编码
2.byte[]转string
String isoString = new String(bytes,"ISO-8859-1");
String srt2=new String(midbytes,"UTF-8");
//jbytearray转c++byte数组
jbyte * arrayBody = env->GetByteArrayElements(data,0);
3
jsize theArrayLengthJ = env->GetArrayLength(data);
4
BYTE * starter = (BYTE *)arrayBody;
1
//jbyteArray 转 c++中的BYTE[]
//jbytearray array
jbyte * olddata = (jbyte*)env->GetByteArrayElements(array, 0);
jsize  oldsize = env->GetArrayLength(array);
BYTE* bytearr = (BYTE*)olddata;
int len = (int)oldsize;
//C++中的BYTE[]转jbyteArray
//nOutSize是BYTE数组的长度 BYTE pData[]
jbyte *by = (jbyte*)pData;
jbyteArray jarray = env->NewByteArray(nOutSize);
env->SetByteArrayRegin(jarray, 0, nOutSize, by);
//jbyteArray 转 char *
char* data = (char*)env->GetByteArrayElements(strIn, 0);
//char* 转jstring
jstring WindowsTojstring(JNIEnv* env, char* str_tmp)
    jstring rtn=0;
    int slen = (int)strlen(str_tmp);
    unsigned short* buffer=0;
    if(slen == 0)
        rtn = env->NewStringUTF(str_tmp);
11
    else
        int length = MultiByteToWideChar(CP_ACP, 0, (LPCSTR)str_tmp, slen, NULL, 0);
        buffer = (unsigned short*)malloc(length*2+1);
        if(MultiByteToWideChar(CP_ACP, 0, (LPCSTR)str_tmp, slen, (LPWSTR)buffer, length) > 0)
            rtn = env->NewString((jchar*)buffer, length);
    if(buffer)
     free(buffer);
 return rtn;
1
//jstring 转 char* 或者 const char*
// jstring str
const char *key = env->GetStringUTFChars(str, 0);
//jboolean isOffer
jsClient->modify(key, isOffer);
//需要释放,否则容易内存泄露
env->ReleaseStringUTFChars(str, key);
//JNI 返回 jbyteArray
JNIEXPORT jbyteArray JNICALL Java_Test_getByteArray(JNIEnv *env, jobject obj)
    jbyteArray firstMacArray = env->NewByteArray( 6 );
    jbyte *bytes = env->GetByteArrayElements( firstMacArray, 0);
    for ( int i = 0; i < sizeof( pAdapterInfo->Address ); i++ )
       bytes[ i ] = pAdapterInfo->Address[ i ];
    env->SetByteArrayRegion(firstMacArray, 0, 6, bytes );
    return firstMacArray;
//jstring to char*
char* jstringTostring(JNIEnv* env, jstring jstr)
    char* rtn = NULL;
    jclass clsstring = env->FindClass("java/lang/String");
    jstring strencode = env->NewStringUTF("utf-8");
    jmethodID mid = env->GetMethodID(clsstring, "getBytes", "(Ljava/lang/String;)[B");
    jbyteArray barr= (jbyteArray)env->CallObjectMethod(jstr, mid, strencode);
    jsize alen = env->GetArrayLength(barr);
    jbyte* ba = env->GetByteArrayElements(barr, JNI_FALSE);
    if (alen > 0)
        rtn = (char*)malloc(alen + 1);
        memcpy(rtn, ba, alen);
        rtn[alen] = 0;
    env->ReleaseByteArrayElements(barr, ba, 0);
    return rtn;
char* to jstring
jstring stoJstring(JNIEnv* env, const char* pat)
    jclass strClass = env->FindClass("Ljava/lang/String;");
    jmethodID ctorID = env->GetMethodID(strClass, "", "([BLjava/lang/String;)V");
    jbyteArray bytes = env->NewByteArray(strlen(pat));
    env->SetByteArrayRegion(bytes, 0, strlen(pat), (jbyte*)pat);
    jstring encoding = env->NewStringUTF("utf-8");
    return (jstring)env->NewObject(strClass, ctorID, bytes, encoding);
//将jstring类型转换成windows类型
char* jstringToWindows( JNIEnv *env, jstring jstr )
    int length = (env)->GetStringLength(jstr );
  const jchar* jcstr = (env)->GetStringChars(jstr, 0 );
  char* rtn = (char*)malloc( length*2+1 );
  int size = 0;
  size = WideCharToMultiByte( CP_ACP, 0, (LPCWSTR)jcstr, length, rtn,(length*2+1), NULL, NULL );
    if( size <= 0 )
return NULL;
(env)->ReleaseStringChars(jstr, jcstr );
rtn[size] = 0;
return rtn;
//将windows类型转换成jstring类型
jstring WindowsTojstring( JNIEnv* env, char* str )
    jstring rtn = 0;
    int slen = strlen(str);
    unsigned short * buffer = 0;
    if( slen == 0 )
        rtn = (env)->NewStringUTF(str );
    else
        int length = MultiByteToWideChar( CP_ACP, 0, (LPCSTR)str, slen, NULL, 0 );
        buffer = (unsigned short *)malloc( length*2 + 1 );
        if( MultiByteToWideChar( CP_ACP, 0, (LPCSTR)str, slen, (LPWSTR)buffer, length ) >0 )
            rtn = (env)->NewString( (jchar*)buffer, length );
    if( buffer )
        free( buffer );
    return rtn;
//从传进来的对象中取出byte[]
jfieldID byteData = (env)->GetFieldID(clazz,"bData","[B");
jbyteArray pDataIn = (jbyteArray) (env)->GetObjectField(objDataIn, byteData);
jsize theArrayLeng = env->GetArrayLength(pDataIn);
//byte[]转为BYTE[]
jbyte * arrayBody = env->GetByteArrayElements(pDataIn,0);
BYTE * jDataIn = (BYTE *)arrayBody;
 JNI开发交流 C/C++,JAVA,android,linux/unix  QQ群:25093009
//将BYTE数组转为jarray
jbyte* byte = (jbyte*)jDataOut;
jbyteArray jarray = env->NewByteArray(theArrayLeng);
env->SetByteArrayRegion(jarray, 0, theArrayLeng, byte);
//给每一个实例的变量付值
(env)->SetObjectField(objDataIn,byteData,jarray);
(env)->SetIntField(objDataIn,pDataInLen,jDataInLen);
(env)->ReleaseByteArrayElements(pDataIn, arrayBody, 0);
原文链接:blog.csdn.net/jacke121/article/details/61419570
