Android Studio Gradle优化方法
风吹稻花香 发表于 2021/06/05 01:09:56 2021/06/05
【摘要】 第一步:打开AS安装所在的位置,用记事本打开“红色框”选中的文件。 如图: 第二步:打开“studio64.exe.vmoptions”文件后修改里面的值,修改后如下: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 2...
如图:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
# *DO NOT* modify this file directly. If there is a value that you would like to override,
# please add it to your user specific configuration file.
# See http://tools.android.com/tech-docs/configuration
-Xms2048m
-Xmx2048m
-XX:MaxPermSize=2048m
-XX:ReservedCodeCacheSize=1024m
-XX:+UseConcMarkSweepGC
-XX:SoftRefLRUPolicyMSPerMB=50
-da
-Djna.nosys=true
-Djna.boot.library.path=
-Djna.debug_load=true
-Djna.debug_load.jna=true
-Dsun.io.useCanonCaches=false
-Djava.net.preferIPv4Stack=true
-XX:+HeapDumpOnOutOfMemoryError
-Didea.paths.selector=AndroidStudio2.0
-Didea.platform.prefix=AndroidStudio
第三步:打开你的项目中的“gradle.properties”文件复制如下内容:
如图:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
# Project-wide Gradle settings.
# IDE (e.g. Android Studio) users:
# Settings specified in this file will override any Gradle settings
# configured through the IDE.
# For more details on how to configure your build environment visit
# http://www.gradle.org/docs/current/userguide/build_environment.html
# The Gradle daemon aims to improve the startup and execution time of Gradle.
# When set to true the Gradle daemon is to run the build.
# TODO: disable daemon on CI, since builds should be clean and reliable on servers
org.gradle.daemon=true
# Specifies the JVM arguments used for the daemon process.
# The setting is particularly useful for tweaking memory settings.
# Default value: -Xmx10248m -XX:MaxPermSize=256m
org.gradle.jvmargs=-Xmx2048m -XX:MaxPermSize=512m -XX:+HeapDumpOnOutOfMemoryError -Dfile.encoding=UTF-8
# When configured, Gradle will run in incubating parallel mode.
# This option should only be used with decoupled projects. More details, visit
# http://www.gradle.org/docs/current/userguide/multi_project_builds.html#sec:decoupled_projects
org.gradle.parallel=true
# Enables new incubating mode that makes Gradle selective when configuring projects.
# Only relevant projects are configured which results in faster builds for large multi-projects.
# http://www.gradle.org/docs/current/userguide/multi_project_builds.html#sec:configuration_on_demand
org.gradle.configureondemand=true
第四步:修改gradle-wrapper.properties文件:
如图:
distributionUrl=https\://services.gradle.org/distributions/gradle-3.4.1-all.zip
第五步:
如图:
Gradle官网下载地址:http://services.gradle.org/distributions
第六步:
如图:--offline
到这里就大功告成了,确实快了很多看看结果吧!
原文链接:blog.csdn.net/jacke121/article/details/73610162
