django ajax上传文件
风吹稻花香 发表于 2021/06/05 01:48:15 2021/06/05
【摘要】 文件上传 https://www.bbsmax.com/A/l1dyQexdem/   <script type="text/javascript">             function uploadImage() { ...
文件上传
                $.ajaxFileUpload({
                    url: "/Struts2Upload/test/uploadAjax.action",
                    secureuri:false,
                    fileElementId:"btn_file",
                    data:{lbg:"json传值并且返回"},
                    dataType: "json",
                    error: function(data, status, e) {
                        alert("shibai");
                        alert(e);
                    success: function(data, textStatus) {
                        alert(textStatus);
                        $('img').attr('src',data.imPath);
        </script>
<input type="file" id="btn_file" name="btn_file" οnchange="uploadImage();">
处理图片:
def pic_class(request): upload_file = request.FILES.get("myfile", None)  # 获取上传的文件,如果没有文件,则默认为None
 file_obj = request.FILES.get('file') if file_obj:   # 处理附件上传到方法
 request_set = {} print('file--obj', file_obj) # user_home_dir = "upload/%s" % (request.user.userprofile.id)
 # accessory_dir = settings.accessory_dir
 # if not os.path.isdir(accessory_dir):
 # os.mkdir(accessory_dir)
 scr = Image.open(file_obj) img= np.asarray(scr)
with open(upload_file, 'wb') as new_file: for chunk in file_obj.chunks(): new_file.write(chunk)
### get the inmemory file
data = request.FILES.get('btn_file') # get the file from the curl
### write the data to a temp file
tup = tempfile.mkstemp() # make a tmp file
f = os.fdopen(tup[0], 'w') # open the tmp file for writing
f.write(data.read()) # write the tmp file
f.close()
### return the path of the file
filepath = tup[1] # get the filepath
return filepath
原文链接:blog.csdn.net/jacke121/article/details/77996205
