Protobuf windows
风吹稻花香 发表于 2021/06/05 00:18:42 2021/06/05
【摘要】   下载地址: https://github.com/protocolbuffers/protobuf/releases   protoc-3.3.0-win32.zip   ncnn的安装方法: 把protobuf-root-dir 换成你的硬盘地址。 download protobuf-3.4.0 from https://g...
下载地址:
ncnn的安装方法:
  1. download protobuf-3.4.0 from https://github.com/google/protobuf/archive/v3.4.0.zip
  2. > cd <protobuf-root-dir>
  3. > mkdir build-vs2017
  4. > cd build-vs2017
  5. > cmake -G"NMake Makefiles" -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=%cd%/install -Dprotobuf_BUILD_TESTS=OFF -Dprotobuf_MSVC_STATIC_RUNTIME=OFF ../cmake
  6. > nmake
  7. > nmake install
配置环境变量:
export PATH=$PATH:/usr/local/protobuf/bin/ export PKG_CONFIG_PATH=/usr/local/protobuf/lib/pkgconfig/
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
Could NOT find GFlags (missing: GFLA
原文链接:blog.csdn.net/jacke121/article/details/101025122
