torch打印网络结构
风吹稻花香 发表于 2021/06/05 01:02:38 2021/06/05
【摘要】   import torch from Pelee_network_v2 import PeleeNet def make_dot(var, params=None): """ Produces Graphviz representation of PyTorch autograd graph Blue nodes are the Variables that ...
  1. import torch
  2. from Pelee_network_v2 import PeleeNet
  3. def make_dot(var, params=None):
  4. """ Produces Graphviz representation of PyTorch autograd graph
  5. Blue nodes are the Variables that require grad, orange are Tensors
  6. saved for backward in torch.autograd.Function
  7. Args:
  8. var: output Variable
  9. params: dict of (name, Variable) to add names to node that
  10. require grad (TODO: make optional)
  11. """
  12. if params is not None:
  13. assert isinstance(params.values()[0], Variable)
  14. param_map = {id(v): k for k, v in params.items()}
  15. node_attr = dict(style='filled',
  16. shape='box',
  17. align='left',
  18. fontsize='12',
  19. ranksep='0.1',
  20. height='0.2')
  21. dot = Digraph(node_attr=node_attr, graph_attr
原文链接:blog.csdn.net/jacke121/article/details/104309744
