cmake find_package opencv 找不到cmake find_package opencv找不到
风吹稻花香 发表于 2021/06/04 23:59:40 2021/06/04
【摘要】   cmake find_package opencv找不到   #find opencv lib find_package(OpenCV REQUIRED               NO_MODULE # should be optional, tells CMake to u...
#find opencv lib
              NO_MODULE # should be optional, tells CMake to use config mode
              PATHS /usr/local # look here
              NO_DEFAULT_PATH) # and don't look anywhere else
2.
windows,linux通用:ok
  1. set (OpenCV_DIR E:/opencv/opencv)
  2. #opencv
  3. find_package(OpenCV REQUIRED)
原文链接:blog.csdn.net/jacke121/article/details/110938303
