mxnet测试网络速度
风吹稻花香 发表于 2021/06/05 00:13:36 2021/06/05
【摘要】   # -*- coding: utf-8 -*-"""File Name: calculate_flops.pyAuthor: liangdepengmail: liangdepeng@gmail.com"""import time import cv2import mxnet as mximport argparseimport numpy as npimpo...
  1. # -*- coding: utf-8 -*-
  2. """
  3. File Name: calculate_flops.py
  4. Author: liangdepeng
  5. mail: liangdepeng@gmail.com
  6. """
  7. import time
  8. import cv2
  9. import mxnet as mx
  10. import argparse
  11. import numpy as np
  12. import json
  13. import re
  14. def parse_args():
  15. parser = argparse.ArgumentParser(description='')
  16. parser.add_argument('-ds', '--data_shapes', default=["data,1,3,112,112"], type=str, nargs='+',
  17. help='data_shapes, format: arg_name,s1,s2,...,sn, example: data,1,3,224,224')
  18. parser.add_argument('-ls', '--label_shapes', default=["label,1,512"], type=str, nargs='+',
  19. help='label_shapes, format: arg_name,s1,s2,...,sn, example: label,1,1,224,224')
  20. parser.add_argument('-s', '--symbol_path', type=str, default=r'softmax_label-symbol.json', help='')
  21. #
  22. return parser.parse_args()
  23. def single_input(path):
  24. img = cv2.imread(path)
  25. # mxnet三通道输入是严格的RGB格式,而cv2.imread的默认是BGR格式,因此需要做一个转换
  26. img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
  27. img = cv2.resize(img, (112, 112))
  28. img = img.transpose(2, 0, 1)
  29. # 添加一个第四维度并构建NDArray
  30. img = img[np.newaxis, :]
  31. array = mx.nd.array(img)
  32. return array
  33. if __name__ == '__main__':
  34. from collections import namedtuple
  35. args = parse_args()
  36. sym = mx.sym.load(args.symbol_path)
  37. data_shapes = list()
  38. data_names = list()
  39. if args.data_shapes is not None and len(args.data_shapes) > 0:
  40. for shape in args.data_shapes:
  41. items = shape.replace('\'', '').replace('"', '').split(',')
  42. data_shapes.append((items[0], tuple([int(s) for s in items[1:]])))
  43. data_names.append(items[0])
  44. label_shapes = None
  45. label_names = list()
  46. if args.label_shapes is not None and len(args.label_shapes) > 0:
  47. label_shapes = list()
  48. for shape in args.label_shapes:
  49. items = shape.replace('\'', '').replace('"', '').split(',')
  50. label_shapes.append((items[0], tuple([int(s) for s in items[1:]])))
  51. label_names.append(items[0])
  52. devs = [mx.cpu()]
  53. if len(label_names) == 0:
  54. label_names = None
  55. model = mx.mod.Module(context=devs, symbol=sym, data_names=data_names, label_names=None)
  56. model.bind(data_shapes=data_shapes, for_training=False)
  57. model._params_dirty = True
  58. model.params_initialized = True
  59. model.save_checkpoint("0412", 1)
  60. time1 = time.time()
  61. # print("模型加载和重建时间:{0}".format(time1 - time0))
  62. Batch = namedtuple("batch", ['data'])
  63. img1_path = r'1054086.jpg'
  64. array1 = single_input(img1_path)
  65. start1 = time.time()
  66. for i in range(40):
  67. start = time.time()
  68. model.forward(Batch([array1]))
  69. vector1 = model.get_outputs()[0].asnumpy()
  70. print("time", time.time() - start, vector1.shape)
  71. print("total time", time.time() - start1)
原文链接:blog.csdn.net/jacke121/article/details/115648268
