Spring Cloud GateWay源码解析实战 - RoutePredicateHandlerMapping
JavaEdge 发表于 2021/06/03 23:53:26 2021/06/03
【摘要】 package org.springframework.cloud.gateway.handler; import java.util.function.Function; import reactor.core.publisher.Mono; import org.springframework.cloud.gateway.config.GlobalCorsP...
import org.springframework.cloud.gateway.config.GlobalCorsProperties;
import org.springframework.cloud.gateway.route.Route;
import org.springframework.cloud.gateway.route.RouteLocator;
import org.springframework.core.env.Environment;
import org.springframework.web.cors.CorsConfiguration;
import org.springframework.web.reactive.handler.AbstractHandlerMapping;
import org.springframework.web.server.ServerWebExchange;
import static org.springframework.cloud.gateway.handler.RoutePredicateHandlerMapping.ManagementPortType.DIFFERENT;
import static org.springframework.cloud.gateway.handler.RoutePredicateHandlerMapping.ManagementPortType.DISABLED;
import static org.springframework.cloud.gateway.handler.RoutePredicateHandlerMapping.ManagementPortType.SAME;
import static org.springframework.cloud.gateway.support.ServerWebExchangeUtils.GATEWAY_HANDLER_MAPPER_ATTR;
import static org.springframework.cloud.gateway.support.ServerWebExchangeUtils.GATEWAY_PREDICATE_ROUTE_ATTR;
import static org.springframework.cloud.gateway.support.ServerWebExchangeUtils.GATEWAY_ROUTE_ATTR;
 * @author Spencer Gibb
public class RoutePredicateHandlerMapping extends AbstractHandlerMapping {
	private final FilteringWebHandler webHandler;
	private final RouteLocator routeLocator;
	private final Integer managementPort;
	private final ManagementPortType managementPortType;
	public RoutePredicateHandlerMapping(FilteringWebHandler webHandler, RouteLocator routeLocator, GlobalCorsProperties globalCorsProperties, Environment environment) {
		this.webHandler = webHandler;
		this.routeLocator = routeLocator; this.managementPort = getPortProperty(environment, "management.server.");
		this.managementPortType = getManagementPortType(environment);
		setOrder(1);
		setCorsConfigurations(globalCorsProperties.getCorsConfigurations());
	private ManagementPortType getManagementPortType(Environment environment) {
		Integer serverPort = getPortProperty(environment, "server.");
		if (this.managementPort != null && this.managementPort < 0) { return DISABLED;
		return ((this.managementPort == null || (serverPort == null && this.managementPort.equals(8080)) || (this.managementPort != 0 && this.managementPort.equals(serverPort))) ? SAME : DIFFERENT);
	private static Integer getPortProperty(Environment environment, String prefix) {
		return environment.getProperty(prefix + "port", Integer.class);
	@Override
	protected Mono<?> getHandlerInternal(ServerWebExchange exchange) {
		// don't handle requests on management port if set and different than server port
		if (this.managementPortType == DIFFERENT && this.managementPort != null && exchange.getRequest().getURI().getPort() == this.managementPort) { return Mono.empty();
		exchange.getAttributes().put(GATEWAY_HANDLER_MAPPER_ATTR, getSimpleName()); return lookupRoute(exchange) // .log("route-predicate-handler-mapping", Level.FINER) //name this .flatMap((Function<Route, Mono<?>>) r -> { exchange.getAttributes().remove(GATEWAY_PREDICATE_ROUTE_ATTR); if (logger.isDebugEnabled()) { logger.debug( "Mapping [" + getExchangeDesc(exchange) + "] to " + r); } exchange.getAttributes().put(GATEWAY_ROUTE_ATTR, r); return Mono.just(webHandler); }).switchIfEmpty(Mono.empty().then(Mono.fromRunnable(() -> { exchange.getAttributes().remove(GATEWAY_PREDICATE_ROUTE_ATTR); if (logger.isTraceEnabled()) { logger.trace("No RouteDefinition found for [" + getExchangeDesc(exchange) + "]"); } })));
	@Override
	protected CorsConfiguration getCorsConfiguration(Object handler, ServerWebExchange exchange) {
		// TODO: support cors configuration via properties on a route see gh-229
		// see RequestMappingHandlerMapping.initCorsConfiguration()
		// also see
		// https://github.com/spring-projects/spring-framework/blob/master/spring-web/src/test/java/org/springframework/web/cors/reactive/CorsWebFilterTests.java
		return super.getCorsConfiguration(handler, exchange);
	// TODO: get desc from factory?
	private String getExchangeDesc(ServerWebExchange exchange) {
		StringBuilder out = new StringBuilder();
		out.append("Exchange: ");
		out.append(exchange.getRequest().getMethod());
		out.append(" ");
		out.append(exchange.getRequest().getURI());
		return out.toString();
	protected Mono<Route> lookupRoute(ServerWebExchange exchange) {
		return this.routeLocator.getRoutes() // individually filter routes so that filterWhen error delaying is not a // problem .concatMap(route -> Mono.just(route).filterWhen(r -> { // add the current route we are testing exchange.getAttributes().put(GATEWAY_PREDICATE_ROUTE_ATTR, r.getId()); return r.getPredicate().apply(exchange); }) // instead of immediately stopping main flux due to error, log and // swallow it .doOnError(e -> logger.error( "Error applying predicate for route: " + route.getId(), e)) .onErrorResume(e -> Mono.empty())) // .defaultIfEmpty() put a static Route not found // or .switchIfEmpty() // .switchIfEmpty(Mono.<Route>empty().log("noroute")) .next() // TODO: error handling .map(route -> { if (logger.isDebugEnabled()) { logger.debug("Route matched: " + route.getId()); } validateRoute(route, exchange); return route; }); /* * TODO: trace logging if (logger.isTraceEnabled()) { * logger.trace("RouteDefinition did not match: " + routeDefinition.getId()); } */
	 * Validate the given handler against the current request.
	 * <p>
	 * The default implementation is empty. Can be overridden in subclasses, for example
	 * to enforce specific preconditions expressed in URL mappings.
	 * @param route the Route object to validate
	 * @param exchange current exchange
	 * @throws Exception if validation failed
	@SuppressWarnings("UnusedParameters")
	protected void validateRoute(Route route, ServerWebExchange exchange) {
	protected String getSimpleName() {
		return "RoutePredicateHandlerMapping";
	public enum ManagementPortType { /** * The management port has been disabled. */
		DISABLED, /** * The management port is the same as the server port. */
		SAME, /** * The management port and server port are different. */
		DIFFERENT;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
文章来源: javaedge.blog.csdn.net,作者:JavaEdge.,版权归原作者所有,如需转载,请联系作者。
原文链接:javaedge.blog.csdn.net/article/details/103467990
