gulp命令执行报错解决
薛定喵君 发表于 2021/06/04 00:27:12 2021/06/04
【摘要】 报错信息: /usr/local/lib/node_modules/gulp/bin/gulp.js:129 gulpInst.start.apply(gulpInst, toRun); ^TypeError: Cannot read property 'apply' of undefined at /usr/local/lib/node_modules/gulp/b...
报错信息:
  1. /usr/local/lib/node_modules/gulp/bin/gulp.js:129
  2. gulpInst.start.apply(gulpInst, toRun);
  3. ^
  4. TypeError: Cannot read property 'apply' of undefined
  5. at /usr/local/lib/node_modules/gulp/bin/gulp.js:129:19
  6. at _combinedTickCallback (internal/process/next_tick.js:67:7)
  7. at process._tickCallback (internal/process/next_tick.js:98:9)
  8. at Module.runMain (module.js:607:11)
  9. at run (bootstrap_node.js:420:7)
  10. at startup (bootstrap_node.js:139:9)
  11. at bootstrap_node.js:535:3
执行命令全局安装gulp-cli
npm i gulp-cli -g
文章来源: blog.csdn.net,作者:薛定喵君,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jsxg2009/article/details/115244228
