springboot项目整合Swagger2
JavaEdge 发表于 2021/06/04 00:01:25 2021/06/04
【摘要】 项目整合 swagger 在聚合工程中的父 pom 工程的 pom 文件中添加依赖 <!-- swagger2 配置 --> <dependency> <groupId>io.springfox</groupId> <artifactId>springfox-swagger2</artifactI...
项目整合 swagger
<dependency>
	<artifactId>springfox-swagger2</artifactId>
	<version>2.4.0</version>
</dependency>
<dependency>
	<artifactId>springfox-swagger-ui</artifactId>
</dependency>
<dependency>
	<groupId>com.github.xiaoymin</groupId>
	<artifactId>swagger-bootstrap-ui</artifactId>
	<version>1.6</version>
</dependency>
  1. 指定API类型为swagger2.0
  2. 定义API文档汇总信息
  3. 指定controller包
  4. 所有controller
源码解析
package springfox.documentation.spi;
import org.springframework.http.MediaType;
import org.springframework.plugin.metadata.SimplePluginMetadata;
public class DocumentationType extends SimplePluginMetadata {
  public static final DocumentationType SWAGGER_12 = new DocumentationType("swagger", "1.2");
  public static final DocumentationType SWAGGER_2 = new DocumentationType("swagger", "2.0");
  public static final DocumentationType SPRING_WEB = new DocumentationType("spring-web", "1.0");
  private final MediaType mediaType; /** * Creates a new instance of {@code SimplePluginMetadata}. */
  public DocumentationType(String name, String version, MediaType mediaType) { super(name, version); this.mediaType = mediaType;
  } public DocumentationType(String name, String version) { this(name, version, MediaType.APPLICATION_JSON);
  } public MediaType getMediaType() { return mediaType;
  } @Override
  public boolean equals(Object o) { if (this == o) { return true; } if (!(o instanceof DocumentationType)) { return false; } if (!super.equals(o)) { return false; } DocumentationType that = (DocumentationType) o; return super.equals(that) && mediaType.equals(that.mediaType); } @Override
  public int hashCode() { int result = super.hashCode(); result = 31 * result + mediaType.hashCode(); return result;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
Swagger JSON Doc
  • 在线编辑地址
    https://editor.swagger.io/
  • 编辑生成样板代码
    所以 swagger 不仅支持代码优先还支持契约优先编程。
文章来源: javaedge.blog.csdn.net,作者:JavaEdge.,版权归原作者所有,如需转载,请联系作者。
原文链接:javaedge.blog.csdn.net/article/details/105852392
