koa中http服务与websocket服务共享端口
薛定喵君 发表于 2021/06/04 00:08:25 2021/06/04
【摘要】 记录下如何在koa中共享http与websocket服务端口 1.安装ws模块 npm install ws 2.服务端 const Koa = require('koa')const app = new Koa()const path = require('path')const ws = require('ws') app.use(req...
1.安装ws模块
npm install ws
2.服务端
  1. const Koa = require('koa')
  2. const app = new Koa()
  3. const path = require('path')
  4. const ws = require('ws')
  5. app.use(require('koa-static')(path.join(__dirname) + '/public'))
  6. let server = app.listen(4000, () => {
  7. let port = server.address().port
  8. console.log('应用实例,访问地址为 http://localhost:' + port)
  9. })
  10. const wss = new ws.Server({ server })
  11. wss.on('connection', function connection(ws) {
  12. ws.on('message', function incoming(message) {
  13. console.log('received: %s', message)
  14. })
  15. })
3.客户端
  1. <!DOCTYPE html>
  2. <html lang="en">
  3. <head>
  4. <meta charset="UTF-8" />
  5. <meta name="viewport" content="width=device-width, initial-scale=1.0" />
  6. <title>ws测试</title>
  7. </head>
  8. <body>
  9. <script>
  10. var ws = new WebSocket('ws://localhost:4000/')
  11. ws.onopen = function () {
  12. console.log('connected')
  13. setTimeout(function () {
  14. ws.send('hello')
  15. }, 2000)
  16. }
  17. ws.onmessage = function (e) {
  18. console.log(e.data)
  19. }
  20. </script>
  21. </body>
  22. </html>
4.运行效果
文章来源: blog.csdn.net,作者:薛定喵君,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jsxg2009/article/details/115244480
