centos yum安装完成桌面环境后无法访问,显示.serverauth.** does not exist解决办法
【摘要】
centos安装桌面环境serverauth.** does not exist解决办法
安装centos的yum安装xwindows界面,出现错误提示:
Host name lookup failure.serverauth.** does not existBefore reporting problems, check ..... to make su...
Before reporting problems, check ..... to make sure that you have the latest version.
解决:
yum update
yum groupinstall "X Window System"
yum groupinstall "Desktop"
文章来源: blog.csdn.net,作者:薛定喵君,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jsxg2009/article/details/115244572
cloudbbs@huaweicloud.com
