HDOJ1003Max Sum
谙忆 发表于 2021/05/28 06:31:41 2021/05/28
【摘要】 Problem Description Given a sequence a[1],a[2],a[3]……a[n], your job is to calculate the max sum of a sub-sequence. For example, given (6,-1,5,4,-7), the max sum in this sequence is 6 + ...
Problem Description
Given a sequence a[1],a[2],a[3]……a[n], your job is to calculate the max sum of a sub-sequence. For example, given (6,-1,5,4,-7), the max sum in this sequence is 6 + (-1) + 5 + 4 = 14.
Input
The first line of the input contains an integer T(1<=T<=20) which means the number of test cases. Then T lines follow, each line starts with a number N(1<=N<=100000), then N integers followed(all the integers are between -1000 and 1000).
Output
For each test case, you should output two lines. The first line is “Case #:”, # means the number of the test case. The second line contains three integers, the Max Sum in the sequence, the start position of the sub-sequence, the end position of the sub-sequence. If there are more than one result, output the first one. Output a blank line between two cases.
Sample Input
2
5 6 -1 5 4 -7
7 0 6 -1 1 -6 7 -5
Sample Output
Case 1:
14 1 4
Case 2:
7 1 6
有2种方法做,我开始不明白题目意思,走了很多弯路。
题目要求是这样的:
输出数组的子序列的最大值。
如果有相同的,开始序列输出小的。
结尾序列输出大的。
/**1003题**/
#include <stdio.h>
#include <stdlib.h>
int a[1000020];
long long int c[3000020],b[1000020];
int main()
{ int t,tt=1; scanf("%d",&t); while(t--) { int i,j,n,a1,a2; scanf("%d",&n); int age=0; if(n!=1) { for(i=0; i<n; i++) scanf("%d",&a[i]); long long int sum=0; for(i=0; i<n; i++) { if(a[i]>=0) { a1=a2=i+1; age=1; break; } } if(age!=1) { int max=a[0]; a1=a2=1; for(i=1; i<n; i++) { if(a[i]>max) { max=a[i]; a1=a2=i+1; } } printf("Case %d:\n",tt); tt++; printf("%d %d %d\n",max,a1,a2); if(t!=0) printf("\n"); } else { int k=0; c[k]=0; long long int max=c[k]; for(i=a1-1;i<n;i++) { c[k]=0; for(j=i;j<n;j++) { c[k]=a[j]+c[k]; if(c[k]<0) break; if(max<c[k]) { a1=i+1; a2=j+1; max=c[k]; } if(max==c[k]) { if(a1>i+1) a1=i+1; if(a2<j+1) a2=j+1; } } k++; } printf("Case %d:\n",tt); tt++; printf("%I64d %d %d\n",max,a1,a2); if(t!=0) printf("\n"); } } if(n==1) { scanf("%d",&a[0]); { printf("Case %d:\n",tt); tt++; printf("%d 1 1\n",a[0]); if(t!=0) printf("\n"); } } } return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
第二种方法:
#include<stdio.h>
int main()
{ int i,ca=1,t,s,e,n,x,now,before,max; scanf("%d",&t); while(t--) { scanf("%d",&n); for(i=1; i<=n; i++) { scanf("%d",&now); if(i==1)//初始化 { max=before=now;
//max保留之前算出来的最大和,before存储目前在读入数据前保留的和,now保留读入数据 x=s=e=1;
//x用来暂时存储before保留的和的起始位置,
//当before>max时将赋在s位置,s,e保留最大和的start和end位置 } else { if(now>now+before)
  //如果之前存储的和加上现在的数据比现在的数据小,
//就把存储的和换成现在的数据,反之就说明数据在递增,可以直接加上 { before=now;
//预存的位置要重置 } else before+=now; } if(before>max)
//跟之前算出来的最大和进行比较,如果大于,位置和数据就要重置 max=before,s=x,e=i; } printf("Case %d:\n%d %d %d\n",ca++,max,s,e); if(t)printf("\n"); } return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
#include <cstdio>
using namespace std; int T,n,m;
int post1,post2,x;//post1表示序列起点,post2表示序列终点,x表示每次更新的起点
int max,now;//max表示最大子序列和,now表示各个子序列的和
int i,j; int main ()
{ scanf ("%d",&T); for (i=1; i<=T; i++) { scanf ("%d%d",&n,&m); max = now = m; post1 = post2 = x = 1;//初始化   for (j=2; j<=n; j++) { scanf ("%d",&m); if (now + m < m)//对于每个数,如果该数加上当前序列和比本身还小   { now = m;//更新区间   x = j;//更新起点   } else now += m;//否则把该数加进序列   if (now > max)//如果当前序列和比已有最大序列和大,更新   { max = now; post1 = x;//记录新的起点和终点   post2 = j; } } printf ("Case %d:\n",i); printf ("%d %d %d\n",max, post1, post2); if (i != T) printf ("\n"); } return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/48598777
