![《[scrapy]scrapy源码分析–信号事件是如何加载以及自定义信号》](https://res-hd.hc-cdn.cn/ecology/9.3.207/v2_resources/ydcomm/libs/images/loading.gif)
环境
背景
我们在写scrapy一些拓展功能的时候,少不了会用到scrapy的extention机制,官网也有提供各种的示例,比如我们在自己手动创建一个新的project的时候,template 会创建一个middlewares.py的文件 ,里面也会有各种和信号打交道的机制,比如这段代码
代码链接:https://github.com/scrapy/scrapy/blob/1.3/scrapy/templates/project/module/middlewares.py.tmpl
from scrapy import signals class CnblogsSpiderMiddleware(object): # Not all methods need to be defined. If a method is not defined, # scrapy acts as if the spider middleware does not modify the # passed objects. @classmethod def from_crawler(cls, crawler): # This method is used by Scrapy to create your spiders. s = cls() crawler.signals.connect(s.spider_opened, signal=signals.spider_opened) return s def process_spider_input(self, response, spider): # Called for each response that goes through the spider # middleware and into the spider. # Should return None or raise an exception. return None def process_spider_output(self, response, result, spider): # Called with the results returned from the Spider, after # it has processed the response. # Must return an iterable of Request, dict or Item objects. for i in result: yield i def process_spider_exception(self, response, exception, spider): # Called when a spider or process_spider_input() method # (from other spider middleware) raises an exception. # Should return either None or an iterable of Response, dict # or Item objects. pass def process_start_requests(self, start_requests, spider): # Called with the start requests of the spider, and works # similarly to the process_spider_output() method, except # that it doesn’t have a response associated. # Must return only requests (not items). for r in start_requests: yield r def spider_opened(self, spider): spider.logger.info('Spider opened: %s' % spider.name) def process_get_response(self, *args, **kwargs): print 'response_received'
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
# passed objects.
@classmethod
s = cls()
return s
return None
for i in result:
yield i
# or Item objects.
pass
yield r
这里就直接将spider_open的”事件” 与当前的 spider open 方法链接起来了,如果还需要一些特定的信号应该如何处理呢?
意外
以上的代码是在使用scrapy 1.3.0在创建新的项目的时候会出问题TypeError: process_start_requests() takes exactly 2 arguments (3 given),一般这种问题都是没有加入self这个参数,然后在观察到官方的scrapy 1.3的template 相关的代码的时候,发现了这个错误
对于官方的这个issue,已经提了pr给它的团队: https://github.com/scrapy/scrapy/pull/2882
分析
关于信号的处理,主要由3个部分组件
信号体
代码所在:https://github.com/scrapy/scrapy/blob/1.3/scrapy/signals.py
""" Scrapy signals These signals are documented in docs/topics/signals.rst. Please don't add new signals here without documenting them there. """ engine_started = object() engine_stopped = object() spider_opened = object() spider_idle = object() spider_closed = object() spider_error = object() request_scheduled = object() request_dropped = object() response_received = object() response_downloaded = object() item_scraped = object() item_dropped = object() # for backwards compatibility stats_spider_opened = spider_opened stats_spider_closing = spider_closed stats_spider_closed = spider_closed item_passed = item_scraped request_received = request_scheduled
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
Scrapy signals
以上就是目前版中常见的信号(或者说事件),拿item_scraped来说,他是怎么被发送给那些被事件订阅者的呢
发生方
代码所在:https://github.com/scrapy/scrapy/blob/eb5d396527c2d63fa6475dfd9b6372a19bce5488/scrapy/core/scraper.py
def _itemproc_finished(self, output, item, response, spider): """ItemProcessor finished for the given ``item`` and returned ``output`` """ self.slot.itemproc_size -= 1 if isinstance(output, Failure): ex = output.value if isinstance(ex, DropItem): logkws = self.logformatter.dropped(item, ex, response, spider) logger.log(*logformatter_adapter(logkws), extra={'spider': spider}) return self.signals.send_catch_log_deferred( signal=signals.item_dropped, item=item, response=response, spider=spider, exception=output.value) else: logger.error('Error processing %(item)s', {'item': item}, exc_info=failure_to_exc_info(output), extra={'spider': spider}) else: logkws = self.logformatter.scraped(output, response, spider) logger.log(*logformatter_adapter(logkws), extra={'spider': spider}) return self.signals.send_catch_log_deferred( signal=signals.item_scraped, item=output, response=response, spider=spider)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
ex = output.value
else:
else:
spider=spider)
我们看到,他是使用self.signals.send_catch_log_deferred方法,将事件发送出去了,那self.signals是个啥呢?继续查看代码
class Scraper(object): def __init__(self, crawler): self.slot = None self.spidermw = SpiderMiddlewareManager.from_crawler(crawler) itemproc_cls = load_object(crawler.settings['ITEM_PROCESSOR']) self.itemproc = itemproc_cls.from_crawler(crawler) self.concurrent_items = crawler.settings.getint('CONCURRENT_ITEMS') self.crawler = crawler self.signals = crawler.signals self.logformatter = crawler.logformatter
1
2
3
4
5
6
7
8
9
10
11
12
self.slot = None
self.signals = crawler.signals 是将crawler的signals赋予scraper的,这里不提不提前吐槽一下,这里的signals的变量的本质 明明就是signals_manager ,导致看的时候有点意义不明确,我们再来看crawler 的代码
代码所在:https://github.com/scrapy/scrapy/blob/master/scrapy/crawler.py
from scrapy.signalmanager import SignalManager from scrapy.exceptions import ScrapyDeprecationWarning from scrapy.utils.ossignal import install_shutdown_handlers, signal_names from scrapy.utils.misc import load_object from scrapy.utils.log import ( LogCounterHandler, configure_logging, log_scrapy_info, get_scrapy_root_handler, install_scrapy_root_handler) from scrapy import signals logger = logging.getLogger(__name__) class Crawler(object): def __init__(self, spidercls, settings=None): if isinstance(settings, dict) or settings is None: settings = Settings(settings) self.spidercls = spidercls self.settings = settings.copy() self.spidercls.update_settings(self.settings) self.signals = SignalManager(self)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
看到这里的就意义明确了,这里singals 变量,实际是实例化了SignalManager 对象,在scraper启动的时候,crawler的想关的内容都会被scraper 拿到,那SignalManager是个啥意儿,我们看看代码
from __future__ import absolute_import from pydispatch import dispatcher from scrapy.utils import signal as _signal class SignalManager(object): def __init__(self, sender=dispatcher.Anonymous): self.sender = sender def connect(self, receiver, signal, **kwargs): """ Connect a receiver function to a signal. The signal can be any object, although Scrapy comes with some predefined signals that are documented in the :ref:`topics-signals` section. :param receiver: the function to be connected :type receiver: callable :param signal: the signal to connect to :type signal: object """ kwargs.setdefault('sender', self.sender) return dispatcher.connect(receiver, signal, **kwargs) def disconnect(self, receiver, signal, **kwargs): """ Disconnect a receiver function from a signal. This has the opposite effect of the :meth:`connect` method, and the arguments are the same. """ kwargs.setdefault('sender', self.sender) return dispatcher.disconnect(receiver, signal, **kwargs) def send_catch_log(self, signal, **kwargs): """ Send a signal, catch exceptions and log them. The keyword arguments are passed to the signal handlers (connected through the :meth:`connect` method). """ kwargs.setdefault('sender', self.sender) return _signal.send_catch_log(signal, **kwargs) def send_catch_log_deferred(self, signal, **kwargs): """ Like :meth:`send_catch_log` but supports returning `deferreds`_ from signal handlers. Returns a Deferred that gets fired once all signal handlers deferreds were fired. Send a signal, catch exceptions and log them. The keyword arguments are passed to the signal handlers (connected through the :meth:`connect` method). .. _deferreds: http://twistedmatrix.com/documents/current/core/howto/defer.html """ kwargs.setdefault('sender', self.sender) return _signal.send_catch_log_deferred(signal, **kwargs) def disconnect_all(self, signal, **kwargs): """ Disconnect all receivers from the given signal. :param signal: the signal to disconnect from :type signal: object """ kwargs.setdefault('sender', self.sender) return _signal.disconnect_all(signal, **kwargs)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
section.
are the same.
signal handlers.
基本上看到这里,我们就基本了解整个信号的运作机制了
使用pydispatch ,通过信号机制,我们轻松的将事件发生方的相关数据发送给相关的接收者
结论
如果我们要自定义一些信号,可以完全按照他的写法,来自己处理一些特定的事件或者信号机制
代码
有一个小demo 关于拿到response 的信号处理机制
代码所在:https://github.com/BruceDone/scrapy_demo/tree/master/cnblogs
参考资料
- https://stackoverflow.com/questions/12394184/scrapy-call-a-function-when-a-spider-quits
- https://stackoverflow.com/questions/30870872/custom-signal-not-being-handled-by-scrapy-internal-api/30871705#30871705
- https://stackoverflow.com/questions/25169897/custom-signals-scrapy
文章来源: brucedone.com,作者:大鱼的鱼塘,版权归原作者所有,如需转载,请联系作者。
原文链接:brucedone.com/archives/1069
