新型冠状病毒转二进制(首发)
【摘要】 新型冠状病毒转二进制(首发)
文章目录
新型冠状病毒转二进制(首发)视频JavaJavaScriptPhpPythonC++
视频
将“新型冠状病毒”转换为二进制???
视频地址:https://www.bilibili.com/video/av86588592
Java
public class Main { pub...
新型冠状病毒转二进制(首发)
视频
将“新型冠状病毒”转换为二进制???
Java
public class Main { public static void main(String[] args) { String str = toBinary("新型冠状病毒"); System.out.println(str); } private static String toBinary(String str) { char[] strChar = str.toCharArray(); StringBuilder result = new StringBuilder(); for (char c : strChar) { result.append(Integer.toBinaryString(c)); } return result.toString(); }
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
JavaScript
function strToBinary(str){ var result = []; var list = str.split(""); for(var i=0;i<list.length;i++){ var item = list[i]; var binaryStr = item.charCodeAt().toString(2); result.push(binartStr); } return result.join("");
console.log(strToBinary("新型冠状病毒"));
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
Php
function StrToBin($str){ $arr = preg_split('/(?<!^)(?!$)/u', $str); foreach($arr as &$v){ $temp = unpack('H*', $v); $v = base_convert($temp[1], 16, 2); unset($temp); } return join(' ',$arr);
echo StrToBin("新型冠状病毒");
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
Python
def encode(s):
return ' '.join([bin(ord(c)).replace('0b', '') for c in s]) def decode(s):
return ''.join([chr(i) for i in [int(b, 2) for b in s.split(' ')]])
var1 = encode("新型冠状病毒")
print(var1)
print(decode(var1))
var1Arr = var1.split(" ")
for i in range(len(var1Arr)):
print(var1Arr[i])
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
C++
#include <iostream>
#include <stdlib.h>
using namespace std;
void outc(char c)
unsigned char k = 0x80
for (int i=0; i<8; i++, k >>= 1){
if (c & k){ printf("1");
} else{ printf("0");
printf(" ");
int main (){
char str[]="新型冠状病毒";
for(int i=0; str[i]; i++){
outc(str[i]);
system("pause");
return true;
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
文章来源: myhub.blog.csdn.net,作者:第三女神程忆难,版权归原作者所有,如需转载,请联系作者。
原文链接:myhub.blog.csdn.net/article/details/104160490
cloudbbs@huaweicloud.com
