HDOJ 1095 A+B for Input-Output Practice (VII)
谙忆 发表于 2021/05/27 00:03:05 2021/05/27
【摘要】 Problem Description Your task is to Calculate a + b. Input The input will consist of a series of pairs of integers a and b, separated by a space, one pair of integers per line. Outp...
Problem Description
Input
Output
For each pair of input integers a and b you should output the sum of a and b, and followed by a blank line.
Sample Input
1 5
10 20
Sample Output
6
30
import java.util.*;
class Main{ public static void main(String args[]){ Scanner sc = new Scanner(System.in); while(sc.hasNext()){ int m=sc.nextInt(); int a= sc.nextInt(); System.out.println(m+a); System.out.println(); } }
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/49334821
