HDOJ 1096 A+B for Input-Output Practice (VIII)
谙忆 发表于 2021/05/26 18:52:55 2021/05/26
【摘要】 Problem Description Your task is to calculate the sum of some integers. Input Input contains an integer N in the first line, and then N lines follow. Each line starts with a integer M...
Problem Description
Input
Input contains an integer N in the first line, and then N lines follow. Each line starts with a integer M, and then M integers follow in the same line.
Output
For each group of input integers you should output their sum in one line, and you must note that there is a blank line between outputs.
Sample Input
3
4 1 2 3 4
5 1 2 3 4 5
3 1 2 3
Sample Output
10
15
6
import java.util.*;
class Main{ public static void main(String args[]){ Scanner sc = new Scanner(System.in); boolean isFirst = true; int m=sc.nextInt(); while(m-->0){ int n=sc.nextInt(); int sum=0; for(int i=0;i<n;i++){ int a=sc.nextInt(); sum+=a; } if(isFirst){ isFirst=false; }else{ System.out.println(); } System.out.println(sum); } }
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/49334857
