HDOJ 2058 The sum problem
谙忆 发表于 2021/05/26 17:16:21 2021/05/26
【摘要】 Problem Description Given a sequence 1,2,3,……N, your job is to calculate all the possible sub-sequences that the sum of the sub-sequence is M. Input Input contains multiple test cases...
Problem Description
Input
Input contains multiple test cases. each case contains two integers N, M( 1 <= N, M <= 1000000000).input ends with N = M = 0.
Output
For each test case, print all the possible sub-sequence that its sum is M.The format is show in the sample below.print a blank line after each test case.
Sample Input
20 10
50 30
0 0
Sample Output
[1,4]
[10,10]
[4,8]
[6,9]
[9,11]
[30,30]
题目的意思:输入两个整数N,M。 N, M( 1 <= N, M <= 1000000000),如果在范围[1,M]内连续整数的和为N,按从小到大次序输出所有这样的连续段,当输入的M,N都为0时结束。
计算的思路:
不考虑子列的终点,而是考虑子列的起点和子列元素的个数,分别记为i,j。由等差数列求和公式,得(i+(i+j-1))*j/2==M ,即(2*i+j-1)*j/2==M(2式),故得i=(2*M/j-j+1)/2,将i,j代回2式,成立则[i,i+j-1]满足条件。注意j最小为1,而由2式,得(j+2*i)*j=2*M,而i>=1,故j*j<=(int)sqrt(2*M).
import java.util.Scanner;
public class Main{ public static void main(String[] args) { Scanner sc = new Scanner(System.in); while(sc.hasNext()){ int n = sc.nextInt(); int m = sc.nextInt(); if(m==0&&n==0){ return ; } int j =(int)Math.pow(2.0*m, 0.5); for(j=j;j>0;j--){ int i; i = (2*m/j-j+1)/2; if(j*(j+2*i-1)/2==m){ System.out.println("["+i+","+(i+j-1)+"]"); } } System.out.println(); } }
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/50616140
