HDOJ(HDU) 2192 MagicBuilding(用Java的Map做了下)
Problem Description
As the increase of population, the living space for people is becoming smaller and smaller. In MagicStar the problem is much worse. Dr. Mathematica is trying to save land by clustering buildings and then we call the set of buildings MagicBuilding. Now we can treat the buildings as a square of size d, and the height doesn’t matter. Buildings of d1,d2,d3….dn can be clustered into one MagicBuilding if they satisfy di != dj(i != j).
Given a series of buildings size , you need to calculate the minimal numbers of MagicBuildings that can be made. Note that one building can also be considered as a MagicBuilding.
Suppose there are five buildings : 1, 2, 2, 3, 3. We make three MagicBuildings (1,3), (2,3), (2) .And we can also make two MagicBuilding :(1,2,3), (2,3). There is at least two MagicBuildings obviously.
Input
The first line of the input is a single number t, indicating the number of test cases.
Each test case starts by n (1≤n≤10^4) in a line indicating the number of buildings. Next n positive numbers (less than 2^31) will be the size of the buildings.
Output
For each test case , output a number perline, meaning the minimal number of the MagicBuilding that can be made.
Sample Input
2
1
2
5
1 2 2 3 3
Sample Output
1
2
其实说了这么多,就是找出现次数最多的那个数。
练习了下Map的使用。也可以不用Map的。
import java.util.Map;
import java.util.Scanner;
import java.util.TreeMap;
public class Main{ public static void main(String[] args) { Scanner sc =new Scanner(System.in); int t =sc.nextInt(); while(t-->0){ Map<Integer,Integer> map = new TreeMap<Integer, Integer>(); int n=sc.nextInt(); int m[] = new int[n]; for(int i=0;i<n;i++){ m[i] = sc.nextInt(); if(map.get(m[i])==null){ map.put(m[i], 1); }else{ map.put(m[i], map.get(m[i])+1); } } int max=0; for(int i=0;i<n;i++){ if(map.get(m[i])>max){ max=map.get(m[i]); } } System.out.println(max); } }
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
- 27
- 28
- 29
- 30
- 31
- 32
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/51326326
