HDOJ(HDU) 2133 What day is it(认识下Java的Calendar类---日期类)
谙忆 发表于 2021/05/26 16:19:18 2021/05/26
【摘要】 Problem Description Today is Saturday, 17th Nov,2007. Now, if i tell you a date, can you tell me what day it is ? Input There are multiply cases. One line is one case. There are thr...
Problem Description
Input
There are three integers, year(0< year<10000), month(0<=month<13), day(0<=day<32).
Output
Output one line.
if the date is illegal, you should output “illegal”. Or, you should output what day it is.
Sample Input
2007 11 17
Sample Output
Saturday
这个题目的某个日期是星期几,和真正的日历是不一样的!!!
所以,用Java的日期类Calendar是过不了的。
只能自己写囖。。。题目意思是:1 1 1是星期一!
而事实上,1 1 1是星期六。不要问我为什么,我也不知道。。。
package cn.hncu.acm;
import java.text.ParseException;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import java.util.Scanner;
public class P2133 { public static void main(String[] args) throws ParseException { String[] week = {"Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"}; int yuee[][]={{0,31,28,31,30,31,30,31,31,30,31,30,31},{0,31,29,31,30,31,30,31,31,30,31,30,31}}; Scanner sc = new Scanner(System.in); while(sc.hasNext()){ int y = sc.nextInt(); int m = sc.nextInt(); int d = sc.nextInt(); if((yunn(y)==0&&m==2&&d==29)||m>12||d>yuee[yunn(y)][m]||m==0||d==0||y==0) { System.out.println("illegal"); continue; } /* //题目是有问题的 //1 1 1 应该是星期六,具体为什么看网上资料。 //这个题目要求已知1 1 1是星期一 String[] week = {"","Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"}; String strTime = y+"-"+m+"-"+d; SimpleDateFormat format = new SimpleDateFormat("yyyy-MM-dd"); Calendar c = Calendar.getInstance(); c.setTime(format.parse(strTime)); System.out.println(week[c.get(Calendar.DAY_OF_WEEK)]); */ int s=0; for(int i=1;i<y;i++){ if(yunn(i)==1){ s+=366; }else{ s+=365; } } for(int i=1;i<m;i++){ s+=yuee[yunn(y)][i]; } s+=d; s=s%7; System.out.println(week[s]); } } public static int yunn(int xx) { if((xx%4==0&&xx%100!=0)||(xx%400==0)) return 1;//是闰年 return 0;//不是闰年 }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
文章来源: chenhx.blog.csdn.net,作者:谙忆,版权归原作者所有,如需转载,请联系作者。
原文链接:chenhx.blog.csdn.net/article/details/51306732
