Standby_pdb_source_file_directory
snowofsummer 发表于 2021/05/25 11:05:03 2021/05/25
【摘要】 参考手册:Doc ID 2274735.1在dataguard环境下需要插入数据库的时候需要使用此参数。手册参考步骤: alter pluggable database <PDB_NAME> close instances=all;alter pluggable database <PDB_NAME> unplug into '/<PATH>/<PDB_NAME>.xml';backup a...
手册参考步骤:
backup as copy pluggable database chewie format '/<PATH>/<PDB_NAME>/%U';
standby数据库需要设置参数:
alter system set standby_pdb_source_file_directory='/<PATH>/<PDB_NAME>';
在主数据库插入pdb:
create pluggable database <PDB_NAME> as clone using '/<PATH>/<PDB_NAME>.xml' copy;
参数说明:
STANDBY_PDB_SOURCE_FILE_DIRECTORY :
参数用于制定备数据源数据文件的位置, 用于安装PDB。
恢复日志:
Thu Mar 16 08:42:04 2017
Recovery created pluggable database <PDB_NAME>
Recovery attempting to copy datafiles for pdb-<PDB_NAME> from source dir-/<PATH>/<PDB_NAME>
Thu Mar 16 08:42:15 2017
Recovery copied files for tablespace SYSTEM
Recovery successfully copied file +<PATH>/DATAFILE/<FILE_NAME> from /<PATH>/<FILE_NAME>
Errors in file /<PATH>/trace/<FILE_NAME>.trc:
ORA-01186: file 1027 failed verification tests
ORA-01157: cannot identify/lock data file 1027 - see DBWR trace file
ORA-01110: data file 1027: '+<PATH>'
File 1027 not verified due to error ORA-01157
ORA-01186: file 1028 failed verification tests
ORA-01157: cannot identify/lock data file 1028 - see DBWR trace file
ORA-01110: data file 1028: '+<PATH>'
File 1028 not verified due to error ORA-01157
ORA-01186: file 1029 failed verification tests
ORA-01157: cannot identify/lock data file 1029 - see DBWR trace file
ORA-01110: data file 1029: '+DATA'
File 1029 not verified due to error ORA-01157
Successfully added datafile 38 to media recovery
Datafile #38: '+<PATH>/DATAFILE/<FILE_NAME>'
Thu Mar 16 08:42:25 2017
Recovery copied files for tablespace SYSAUX
