dataguard 日志应用失败-ora-600 2619
snowofsummer 发表于 2021/05/23 15:42:49 2021/05/23
【摘要】 报错信息:MRP进程起不来, 报错:ORA-00600: internal error code, arguments: [2619], [227424], [], [], [], [], [], [], [], [], [], []18 ORA-00600: internal error code, arguments: [2619], [227424], [], [], [], [], ...
报错信息:
18 ORA-00600: internal error code, arguments: [2619], [227424], [], [], [], [], [], [], [], [], [], []
19 Incident details in: /u01/oracle/diag/rdbms/oradb/oradb/incident/incdir_48266/oradb_pr00_5429_i48266.trc
20 Completed: ALTER DATABASE RECOVER managed standby database disconnect from session
21 Use ADRCI or Support Workbench to package the incident.
22 See Note 411.1 at My Oracle Support for error and packaging details.
23 Errors with log /oraarchivelog/oradb/oradb_1_227424_866810169.arc
24 MRP0: Background Media Recovery terminated with error 600
25 Errors in file /u01/oracle/diag/rdbms/oradb/oradb/trace/oradb_pr00_5429.trc:
26 ORA-00600: internal error code, arguments: [2619], [227424], [], [], [], [], [], [], [], [], [], []
27 Recovery interrupted!
导致问题原因:
对应的归档日志损坏。
处理方法:
1,手动删除oradb_1_227424_866810169归档日志文件,并重新启动日志应用进程通过GAP自动从主数据库获取日志,重启应用。
2,删除问题归档日志,手动从主数据库拷贝对应归档日志,重新启动应用进程。
