PHP 高级特性四之 SMTP 邮件发送
崔庆才丨静觅 发表于 2021/05/22 02:13:00 2021/05/22
【摘要】 综述 PHP 的邮件发送最常见的便是 SMTP,通过编写一个 Smtp 类,设置好 smtp 服务器,邮箱用户名,密码,即可实现邮件的发送 邮件发送 邮件发送的类如下,文件名叫做 1 email.class.php 123456789101112131415161718192021222324252627282930313233343536373...
综述
邮件发送
邮件发送的类如下,文件名叫做
1
email.class.php
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
<?php
/* smtp class */
class smtp {
/* Public Variables */
var $smtp_port;
var $time_out;
var $host_name;
var $log_file;
var $relay_host;
var $debug;
var $auth;
var $user;
var $pass;
/* Private Variables */
var $sock;
/* Constractor */
function smtp($relay_host = "", $smtp_port = 25, $auth = false, $user, $pass) {
$this->debug = FALSE;
$this->smtp_port = $smtp_port;
$this->relay_host = $relay_host;
$this->time_out = 30; //is used in fsockopen()
$this->auth = $auth; //auth
$this->user = $user;
$this->pass = $pass;
$this->host_name = "localhost"; //is used in HELO command
$this->log_file = "";
$this->sock = FALSE;
/* Main Function */
function sendmail($to, $from, $subject = "", $body = "", $mailtype, $cc = "", $bcc = "", $additional_headers = "") {
$mail_from = $this->get_address($this->strip_comment($from));
$body = preg_replace("/(^|(\r\n))(\.)/", "\1.\3", $body);
$header = "MIME-Version:1.0\r\n";
if ($mailtype == "HTML") {
$header.= "Content-Type:text/html\r\n";
$header.= "To: " . $to . "\r\n";
if ($cc != "") {
$header.= "Cc: " . $cc . "\r\n";
$header.= "From: $from<" . $from . ">\r\n";
$header.= "Subject: " . $subject . "\r\n";
$header.= $additional_headers;
$header.= "Date: " . date("r") . "\r\n";
$header.= "X-Mailer:By Redhat (PHP/" . phpversion() . ")\r\n";
list($msec, $sec) = explode(" ", microtime());
$header.= "Message-ID: <" . date("YmdHis", $sec) . "." . ($msec * 1000000) . "." . $mail_from . ">\r\n";
$TO = explode(",", $this->strip_comment($to));
if ($cc != "") {
$TO = array_merge($TO, explode(",", $this->strip_comment($cc)));
if ($bcc != "") {
$TO = array_merge($TO, explode(",", $this->strip_comment($bcc)));
$sent = TRUE;
foreach ($TO as $rcpt_to) {
$rcpt_to = $this->get_address($rcpt_to);
if (!$this->smtp_sockopen($rcpt_to)) {
$this->log_write("Error: Cannot send email to " . $rcpt_to . "\n");
$sent = FALSE;
continue;
if ($this->smtp_send($this->host_name, $mail_from, $rcpt_to, $header, $body)) {
$this->log_write("E-mail has been sent to <" . $rcpt_to . ">\n");
$this->log_write("Error: Cannot send email to <" . $rcpt_to . ">\n");
$sent = FALSE;
fclose($this->sock);
$this->log_write("Disconnected from remote host\n");
return $sent;
/* Private Functions */
function smtp_send($helo, $from, $to, $header, $body = "") {
if (!$this->smtp_putcmd("HELO", $helo)) {
return $this->smtp_error("sending HELO command");
//auth
if ($this->auth) {
if (!$this->smtp_putcmd("AUTH LOGIN", base64_encode($this->user))) {
if (!$this->smtp_putcmd("", base64_encode($this->pass))) {
if (!$this->smtp_putcmd("MAIL", "FROM:<" . $from . ">")) {
return $this->smtp_error("sending MAIL FROM command");
if (!$this->smtp_putcmd("RCPT", "TO:<" . $to . ">")) {
return $this->smtp_error("sending RCPT TO command");
if (!$this->smtp_putcmd("DATA")) {
return $this->smtp_error("sending DATA command");
if (!$this->smtp_message($header, $body)) {
return $this->smtp_error("sending message");
if (!$this->smtp_eom()) {
return $this->smtp_error("sending <CR><LF>.<CR><LF> [EOM]");
if (!$this->smtp_putcmd("QUIT")) {
return $this->smtp_error("sending QUIT command");
return TRUE;
function smtp_sockopen($address) {
if ($this->relay_host == "") {
return $this->smtp_sockopen_mx($address);
return $this->smtp_sockopen_relay();
function smtp_sockopen_relay() {
$this->log_write("Trying to " . $this->relay_host . ":" . $this->smtp_port . "\n");
$this->sock = @fsockopen($this->relay_host, $this->smtp_port, $errno, $errstr, $this->time_out);
if (!($this->sock && $this->smtp_ok())) {
$this->log_write("Error: Cannot connenct to relay host " . $this->relay_host . "\n");
$this->log_write("Error: " . $errstr . " (" . $errno . ")\n");
return FALSE;
$this->log_write("Connected to relay host " . $this->relay_host . "\n");
return TRUE;;
function smtp_sockopen_mx($address) {
$domain = preg_replace("/^.+@([^@]+)$/", "\1", $address);
if (!@getmxrr($domain, $MXHOSTS)) {
$this->log_write("Error: Cannot resolve MX \"" . $domain . "\"\n");
return FALSE;
foreach ($MXHOSTS as $host) {
$this->log_write("Trying to " . $host . ":" . $this->smtp_port . "\n");
$this->sock = @fsockopen($host, $this->smtp_port, $errno, $errstr, $this->time_out);
$this->log_write("Warning: Cannot connect to mx host " . $host . "\n");
continue;
$this->log_write("Connected to mx host " . $host . "\n");
return TRUE;
$this->log_write("Error: Cannot connect to any mx hosts (" . implode(", ", $MXHOSTS) . ")\n");
return FALSE;
function smtp_message($header, $body) {
fputs($this->sock, $header . "\r\n" . $body);
$this->smtp_debug("> " . str_replace("\r\n", "\n" . "> ", $header . "\n> " . $body . "\n> "));
return TRUE;
function smtp_eom() {
fputs($this->sock, "\r\n.\r\n");
$this->smtp_debug(". [EOM]\n");
return $this->smtp_ok();
function smtp_ok() {
$response = str_replace("\r\n", "", fgets($this->sock, 512));
$this->smtp_debug($response . "\n");
if (!preg_match("/^[23]/", $response)) {
fputs($this->sock, "QUIT\r\n");
fgets($this->sock, 512);
$this->log_write("Error: Remote host returned \"" . $response . "\"\n");
return FALSE;
return TRUE;
function smtp_putcmd($cmd, $arg = "") {
if ($arg != "") {
if ($cmd == "") $cmd = $arg;
else $cmd = $cmd . " " . $arg;
fputs($this->sock, $cmd . "\r\n");
$this->smtp_debug("> " . $cmd . "\n");
function smtp_error($string) {
$this->log_write("Error: Error occurred while " . $string . ".\n");
return FALSE;
function log_write($message) {
$this->smtp_debug($message);
if ($this->log_file == "") {
return TRUE;
$message = date("M d H:i:s ") . get_current_user() . "[" . getmypid() . "]: " . $message;
if (!@file_exists($this->log_file) || !($fp = @fopen($this->log_file, "a"))) {
$this->smtp_debug("Warning: Cannot open log file \"" . $this->log_file . "\"\n");
return FALSE;;
flock($fp, LOCK_EX);
fputs($fp, $message);
fclose($fp);
return TRUE;
function strip_comment($address) {
$comment = "/\([^()]*\)/";
while (preg_match($comment, $address)) {
$address = preg_replace($comment, "", $address);
return $address;
function get_address($address) {
$address = preg_replace("/([ \t\r\n])+/", "", $address);
$address = preg_replace("/^.*<(.+)>.*$/", "\1", $address);
return $address;
function smtp_debug($message) {
if ($this->debug) {
echo $message;
然后便是一个 php 文件引用该文件,设置好各种参数
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
<!DOCTYPE>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>发送状态</title>
</head>
<body>
<?php
require_once "email.class.php";
//SMTP服务器
$smtpserver = "smtp.163.com";
//SMTP端口号?
$smtpserverport = 25;
//SMTP发邮件的邮箱
$smtpusermail = "cqc@163.com";
//发给谁
$smtpemailto = $_POST['toemail'];
//SMTP用户名,不加@163.com
$smtpuser = "cqc";
//SMTP用户密码
$smtppass = "wtf";
//主题
$mailtitle = $_POST['topic'];
//构建内容
$mailcontent = "TA的名字 ".$_POST['name']."<br>内容: ".$_POST['content'];
//邮件内容为HTML格式
$mailtype = "HTML";
//实例化对象
$smtp = new smtp($smtpserver,$smtpserverport,true,$smtpuser,$smtppass);
//关闭调试信息
$smtp->debug = false;
//发送邮件
$state = $smtp->sendmail($smtpemailto, $smtpusermail, $mailtitle, $mailcontent, $mailtype);
//检查发送状态
if($state==""){
echo "邮件发送失败,请检查密码或其他设置";
}else if(strlen($state)!=0){
//发送成功
echo "邮件发送成功";
}else{
echo "未知错误";
</body>
</html>
最后是一个表单提交,包括目的邮箱,主题,内容
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
<!DOCTYPE>
<html>
<head>
<title>PHP利用SMTP发送邮件范例</title>
</head>
<body>
<form action="sendmail.php" method="post">
<p>收件人:<input type="text" name="toemail" /></p>
<p>标&nbsp;&nbsp;题:<input type="text" name="topic" /></p>
<p>姓&nbsp;&nbsp;名:<input type="text" name="name" /></p>
<p>内&nbsp;&nbsp;容:<textarea name="content" cols="50" rows="5"></textarea></p>
<p><input type="submit" value="发送" /></p>
</form>
</body>
</html>
代码下载
代码下载
文章来源: cuiqingcai.com,作者:崔庆才,版权归原作者所有,如需转载,请联系作者。
原文链接:cuiqingcai.com/1470.html
