Hadoop环境的主机名解析
pilchard 发表于 2021/05/10 15:56:42 2021/05/10
【摘要】 介绍hadoop 环境中dns 解析过程, linux dns 解析原理,提供最佳实践。
问题背景
​ 在网络里,每台机器都有两个身份证。人出于管理的目的,颁发的ID是主机名。而在“机器世界”中,相互之间的交流却基于IP地址,因而在人不感知的角落,每时每刻都在进行着成千上万次的转换,主机名–> IP地址。提到解析,就绕不开“专业人士” DNS。作为久经考验的互联网设施,在和大数据结为一对时,却也像新婚的小夫妻难免磕磕碰碰,互相嫌弃。要么是解析慢了,影响大数据响应。要么是DNS抱怨家务活太多,压力太大。还有就是已经注释了DNS 的配置,结果还要合DNS纠缠不清。两者真的是八字不合?
问题样例
  1. 问题一 DNS解析慢影响大数据性能
    该问题主要发生在与连接建立阶段,卡顿10-15s的情况。如HDFS客户端的如下日志打印和jstack信息:
    # 日志打印:
    2021-04-22 15:15:01,038 | DEBUG | pool-13-thread-165 | Connecting to 100.76.18.13/100.76.18.13:25000 | org.apache.hadoop.ipc.Client$Connection.setupIOstreams(Client.java:814)
    2021-04-22 15:15:14,672 | DEBUG | pool-13-thread-165 | PrivilegedAction as:hive/hadoop.hadoop.com@HADOOP.COM (auth:KERBEROS) from:org.apache.hadoop.ipc.Client$Connection.setupIOstreams(Client.java:829) | org.apache.hadoop.security.UserGroupInformation.logPrivilegedAction(UserGroupInformation.java:1756)
    # jstack信息:
    "pool-13-thread-165" #2003 prio=5 os_prio=0 tid=0x00002b56846d0800 nid=0x4bb9 runnable [0x00002b56c1d4b000]
       java.lang.Thread.State: RUNNABLE
    	at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
    	at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:929)
    	at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1324)
    	at java.net.InetAddress.getAllByName0(InetAddress.java:1277)
    	at java.net.InetAddress.getAllByName(InetAddress.java:1193)
    	at java.net.InetAddress.getAllByName(InetAddress.java:1127)
    	at java.net.InetAddress.getByName(InetAddress.java:1077)
    	at org.apache.hadoop.security.SecurityUtil$QualifiedHostResolver.getInetAddressByName(SecurityUtil.java:684)
    	at org.apache.hadoop.security.SecurityUtil$QualifiedHostResolver.getByExactName(SecurityUtil.java:657)
    	at org.apache.hadoop.security.SecurityUtil$QualifiedHostResolver.getByName(SecurityUtil.java:625)
    	at org.apache.hadoop.security.SecurityUtil.getByName(SecurityUtil.java:549)
    	at org.apache.hadoop.net.NetUtils.getLocalInetAddress(NetUtils.java:684)
    	at org.apache.hadoop.ipc.Client$Connection.setupConnection(Client.java:701)
    	- locked <0x000000060130ef08> (a org.apache.hadoop.ipc.Client$Connection)
    	at org.apache.hadoop.ipc.Client$Connection.setupIOstreams(Client.java:823)
    	at org.apache.hadoop.ipc.Client$Connection.access$3700(Client.java:436)
    	at org.apache.hadoop.ipc.Client.getConnection(Client.java:1613)
  2. 问题二 大数据DDOS攻击DNS服务器
    DNS 服务器压力太大,一查发现有1000+的节点在解析不存在的条目。难道被DDOS攻击了?
    31-MAR-2021 17:56:35.464 queries: client x.x.x.x#55638: query: manager IN A +
    通过日志记录发现都是大数据节点发起的解析请求。
  3. 问题三 如何正确的关闭DNS
    在集群中配置了DNS,影响到了业务的请求。注释了/etc/resolve.conf
    #nameserver 170.4.0.101
    修改了/etc/nssswitch.conf
    hosts:      files dns myhostname
    hosts:      files myhostname
    本地也没有启动bind服务,为何还是需要通过DNS服务进行解析。
原理分析
大数据平台主要在两个场景下,需要进行DNS的解析。一是将集群内的节点名,转换为IP地址。二是在配置了kerberos之后,安全认证过程中进行Host 的转换。根据经验,场景一由于主机名固定且加入了/etc/hosts,一般不会通过DNS进行主机名解析。而场景二中,主机名不固定,可能存在漏加或错加的情况,问题较为多发。
  1. 场景二中,在kerberos环境下,与服务端通过SASL协议建立连接时,需要从客户端的kerberos principal中拿到主机名然后获取本地的地址信息。
    org.apache.hadoop.ipc.Conenction#setupConnection
            * Bind the socket to the host specified in the principal name of the
            * client, to ensure Server matching address of the client connection
            * to host name in principal passed.
           InetSocketAddress bindAddr = null;
           if (ticket != null && ticket.hasKerberosCredentials()) {
             KerberosInfo krbInfo =
               remoteId.getProtocol().getAnnotation(KerberosInfo.class);
             if (krbInfo != null) {
               String principal = ticket.getUserName();
               String host = SecurityUtil.getHostFromPrincipal(principal);
               // If host name is a valid local address then bind socket to it
               InetAddress localAddr = NetUtils.getLocalInetAddress(host);
               if (localAddr != null) {
                 this.socket.setReuseAddress(true);
                 localAddr = NetUtils.bindToLocalAddress(localAddr,
                     bindToWildCardAddress);
                 LOG.debug("Binding {} to {}", principal,
                     (bindToWildCardAddress) ? "0.0.0.0" : localAddr);
                 this.socket.bind(new InetSocketAddress(localAddr, 0));
    为何要根据principal 去获取地址信息?该改动是在开源单HADOOP-7215 中引入的,由于在HADOOP-7104中增加了客户端主机名和客户端 kerberos principal中主机名比对。为避免比对失败,客户端不应使用随机的IP地址,而应使用kerberos principal 中主机名字段对应的IP地址。
    HADOOP-7104 introduced a change where RPC server matches client's hostname with the hostname specified in the client's Kerberos principal name. RPC client binds the socket to a random local address, which might not match the hostname specified in the principal name. This results authorization failure of the client at the server.
  2. NetUtils#getLocalInetAddress 中,获取主机名对应地址并检查是否为本地地址。非本地地址时返回null使用随机地址。
       * Checks if {@code host} is a local host name and return {@link InetAddress}
       * corresponding to that address.
       * @param host the specified host
       * @return a valid local {@link InetAddress} or null
       * @throws SocketException if an I/O error occurs
      public static InetAddress getLocalInetAddress(String host)
          throws SocketException {
        if (host == null) {
          return null;
        InetAddress addr = null;
        try {
          addr = SecurityUtil.getByName(host);
          if (NetworkInterface.getByInetAddress(addr) == null) {
            addr = null; // Not a local address
        } catch (UnknownHostException ignore) { }
        return addr;
  3. getByName 时根据配置hadoop.security.token.service.use_ip (HADOOP-7808)来决定如何解析主机名。
       * Resolves a host subject to the security requirements determined by
       * hadoop.security.token.service.use_ip. Optionally logs slow resolutions.
       * @param hostname host or ip to resolve
       * @return a resolved host
       * @throws UnknownHostException if the host doesn't exist
      @InterfaceAudience.Private
      public static
      InetAddress getByName(String hostname) throws UnknownHostException {
        if (logSlowLookups || LOG.isTraceEnabled()) {
          StopWatch lookupTimer = new StopWatch().start();
          InetAddress result = hostResolver.getByName(hostname);
          long elapsedMs = lookupTimer.stop().now(TimeUnit.MILLISECONDS);
          if (elapsedMs >= slowLookupThresholdMs) {
            LOG.warn("Slow name lookup for " + hostname + ". Took " + elapsedMs +
                " ms.");
          } else if (LOG.isTraceEnabled()) {
            LOG.trace("Name lookup for " + hostname + " took " + elapsedMs +
                " ms.");
          return result;
          return hostResolver.getByName(hostname);
    当前存在两个解析类,StandardHostResolver 和QualifiedHostResolver ,前者为标准的java主机名解析,而后者在解析性能和安全层面进行了加强。
       * This an alternate resolver with important properties that the standard
       * java resolver lacks:
       * 1) The hostname is fully qualified.  This avoids security issues if not
       *    all hosts in the cluster do not share the same search domains.  It
       *    also prevents other hosts from performing unnecessary dns searches.
       *    In contrast, InetAddress simply returns the host as given.
       * 2) The InetAddress is instantiated with an exact host and IP to prevent
       *    further unnecessary lookups.  InetAddress may perform an unnecessary
       *    reverse lookup for an IP.
       * 3) A call to getHostName() will always return the qualified hostname, or
       *    more importantly, the IP if instantiated with an IP.  This avoids
       *    unnecessary dns timeouts if the host is not resolvable.
       * 4) Point 3 also ensures that if the host is re-resolved, ex. during a
       *    connection re-attempt, that a reverse lookup to host and forward
       *    lookup to IP is not performed since the reverse/forward mappings may
       *    not always return the same IP.  If the client initiated a connection
       *    with an IP, then that IP is all that should ever be contacted.
       * NOTE: this resolver is only used if:
       *       hadoop.security.token.service.use_ip=false
    对传入的参数进行了标准化处理后,调用了对应的方法进程解析。如hadoop.hadoop.com,则会在末尾增加. 成为FQDN,避免search domain 不一致带来的安全问题或不必要的DNS解析。
        InetAddress getByExactName(String host) {
          // InetAddress will use the search list unless the host is rooted
          // with a trailing dot.  The trailing dot will disable any use of the
          // search path in a lower level resolver.  See RFC 1535.
          String fqHost = host;
          if (!fqHost.endsWith(".")) fqHost += ".";
          try {
            addr = getInetAddressByName(fqHost);
            // can't leave the hostname as rooted or other parts of the system
            // malfunction, ex. kerberos principals are lacking proper host
            // equivalence for rooted/non-rooted hostnames
            addr = InetAddress.getByAddress(host, addr.getAddress());
          } catch (UnknownHostException e) {
            // ignore, caller will throw if necessary
          return addr;
  4. 最终调用了JDK的native方法Inet6AddressImpl或Ine4AddressImpl#lookupAllHostAddr解析主机名。根据JDK的代码,该方法调用标准调用 getaddrinfo 。
        memset(&hints, 0, sizeof(hints));
        hints.ai_flags = AI_CANONNAME;
        hints.ai_family = AF_UNSPEC;
        error = getaddrinfo(hostname, NULL, &hints, &res);
        last_i = gaih_inet (name, pservice, hints, end, &naddrs, &tmpbuf);
    	 int err = __nscd_getai (name, &air, &h_errno);
    	 fct4 = __nss_lookup_function (nip, "gethostbyname4_r");
    _nss_files_gethostbyname4_r
    _nss_dns_gethostbyname4_r
    getaddrinfo 是glibc 中的标准调用,封装了gethostbyname 和 getservbyname 两个系统调用,屏蔽了IPv4 IPv6的差异。
    Given node and service, which identify an Internet host and a service, getaddrinfo() returns one or more addrinfo structures, each of which contains an Internet address that can be specified in a call to bind(2) or connect(2).The getaddrinfo() function combines the functionality provided by the gethostbyname(3) and getservbyname(3) functions into a single interface, but unlike the latter functions, getaddrinfo() is reentrant and allows programs to eliminate IPv4-versus-IPv6 dependencies.
  5. 为了解详细的解析过程,使用如下样例代码进行测试。
    import java.net.InetAddress;
    import java.net.UnknownHostException;
    public class Test
        public static void main(String[] args)
            try {
                InetAddress addr = InetAddress.getByName("hadoop.hadoop.com.");
                System.out.println(addr);
                e.printStackTrace();
    编译后,使用strace命令跟踪其调用过程:
    javac Test.java
    strace -tt -T -f -i -s 4096 java Test  >test.log 2>&1
  6. 根据strace结果(hosts中无记录,dns中无记录),先连接nscd进行hosts查询,耗时5秒:
    [pid 10987] 16:24:06 connect(7, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = 0 <0.000012>
    [pid 10987] 16:24:06 sendto(7, "\2\0\0\0\r\0\0\0\6\0\0\0hosts\0", 18, MSG_NOSIGNAL, NULL, 0) = 18 <0.000010>
    [pid 10987] 16:24:06 poll([{fd=7, events=POLLIN|POLLERR|POLLHUP}], 1, 5000) = 1 ([{fd=7, revents=POLLIN|POLLHUP}]) <0.000009>
    [pid 10987] 16:24:06 recvmsg(7, {msg_name(0)=NULL, msg_iov(2)=[{"hosts\0", 6}, {"\270O\3\0\0\0\0\0", 8}], msg_controllen=24, {cmsg_len=20, cmsg_level=SOL_SOCKET, cmsg_type=SCM_RIGHTS, {8}}, msg_flags=MSG_CMSG_CLOEXEC}, MSG_CMSG_CLOEXEC) = 14 <0.000009>
    [pid 10987] 16:24:06 mmap(NULL, 217016, PROT_READ, MAP_SHARED, 8, 0) = 0x7f6e4199d000 <0.000010>
    [pid 10987] 16:24:06 socket(PF_FILE, 0x80801 /* SOCK_??? */, 0) = 7 <0.000009>
    [pid 10987] 16:24:06 connect(7, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = 0 <0.000011>
    [pid 10987] 16:24:06 sendto(7, "\2\0\0\0\4\0\0\0\23\0\0\0hadoop.hadoop.com.\0", 31, MSG_NOSIGNAL, NULL, 0) = 31 <0.000010>
    [pid 10987] 16:24:06 poll([{fd=7, events=POLLIN|POLLERR|POLLHUP}], 1, 5000 <unfinished ...>
    [pid 10987] 16:24:11 <... poll resumed> ) = 0 (Timeout) <5.001059>
    [pid 10987] 16:24:11 close(7)           = 0 <0.000011>
    读取nssswitch.conf ,先从hosts文件解析,解析失败后通过dns解析。
    [pid 28793] 09:54:28.118467 [    7f225b2f4eb0] open("/etc/nsswitch.conf", O_RDONLY) = 7 <0.000012>
    [pid 28793] 09:54:28.119931 [    7f225b2f4ecd] open("/etc/hosts", O_RDONLY|O_CLOEXEC) = 7 <0.000009>
    读取resolv.conf,连接DNS查询两次(耗时10s)
    [pid 10987] 16:24:11 [    7f225b2f4eb0] open("/etc/resolv.conf", O_RDONLY) = 7 <0.000008>
    [pid 10987] 16:24:11 socket(PF_INET, 0x802 /* SOCK_??? */, IPPROTO_IP) = 7 <0.000011>
    [pid 10987] 16:24:11 connect(7, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("170.4.0.101")}, 28) = 0 <0.000010>
    [pid 10987] 16:24:11 poll([{fd=7, events=POLLOUT}], 1, 0) = 1 ([{fd=7, revents=POLLOUT}]) <0.000008>
    [pid 10987] 16:24:11 sendto(7, "\231{\1\0\0\1\0\0\0\0\0\0\6hadoop\6hadoop\3com\0\0"..., 35, MSG_NOSIGNAL, NULL, 0) = 35 <0.000017>
    [pid 10987] 16:24:11 poll([{fd=7, events=POLLIN}], 1, 5000 <unfinished ...>
    [pid 10987] 16:24:16 <... poll resumed> ) = 0 (Timeout) <5.003036>
    [pid 10987] 16:24:16 poll([{fd=7, events=POLLOUT}], 1, 0) = 1 ([{fd=7, revents=POLLOUT}]) <0.000009>
    [pid 10987] 16:24:16 sendto(7, "\231{\1\0\0\1\0\0\0\0\0\0\6hadoop\6hadoop\3com\0\0"..., 35, MSG_NOSIGNAL, NULL, 0) = 35 <0.000016>
    [pid 10987] 16:24:16 poll([{fd=7, events=POLLIN}], 1, 5000 <unfinished ...>
    [pid 10987] 16:24:21 <... poll resumed> ) = 0 (Timeout) <5.003870>
    [pid 10987] 16:24:21 close(7)           = 0 <0.000015>
    [pid 10987] 16:24:21 lseek(3, 53540581, SEEK_SET) = 53540581 <0.000010>
  7. 整体的解析流程如下:
    1)连接nscd 从缓存中进行解析。
    2)尝试本地进行解析,根据nssswitch.conf 配置顺序进行尝试。
    # nssswitch.conf
    hosts:  	files dns  #为先hosts后连接dns解析
    # reslov.conf
    options
       timeout: 5           # 5秒超时
       attempts: 2          # 重试两次
  8. 另外一些老的操作系统,修改nssswitch.conf 后,nscd进程并不感知文件改变,需要手动重启nscd进程。
    # man nscd
    NOTES
           Nscd  doesn't  know  anything  about the underlying protocols for a service.  This also means, that if you change /etc/resolv.conf for DNS queries, nscd will continue to use the old one if you have
           configured /etc/nsswitch.conf to use DNS for host lookups.  In such a case, you need to restart nscd.
解析流程,nscd --> hosts --> dns(默认两次重试),nscd内部hosts–> dns(一次重试)。
尽量写入hosts, 虽然不便于管理,但是稳定高效。应当优先尽量将对应关系写入hosts文件,这样也能避免分布式的解析请求给DNS服务带来不必要的压力。
优化配置, resolv.conf 中默认的超时时间和重试次数可进行调优,在无法解析的情况下减小性能影响。
相关链接
HADOOP-7215
HADOOP-7104
HADOOP-7808
nsswitch.conf
resolv.conf
