【环境篇】第 1 节 • JDK 介绍和安装
小傅哥 发表于 2021/04/24 00:23:32 2021/04/24
【摘要】 一、JDK、JRE、JVM 的关系 1. Java 平台标准(JDK 8) Oracle has two products that implement Java Platform Standard Edition (Java SE) 8: Java SE Development Kit (JDK) 8 and Java SE Runtime Environm...
一、JDK、JRE、JVM 的关系
1. Java 平台标准(JDK 8)
Oracle has two products that implement Java Platform Standard Edition (Java SE) 8: Java SE Development Kit (JDK) 8 and Java SE Runtime Environment (JRE) 8.
JDK 8 is a superset of JRE 8, and contains everything that is in JRE 8, plus tools such as the compilers and debuggers necessary for developing applets and applications. JRE 8 provides the libraries, the Java Virtual Machine (JVM), and other components to run applets and applications written in the Java programming language. Note that the JRE includes components not required by the Java SE specification, including both standard and non-standard Java components.
The following conceptual diagram illustrates the components of Oracle’s Java SE products:
Description of Java Conceptual Diagram
文章来源: bugstack.blog.csdn.net,作者:小傅哥,版权归原作者所有,如需转载,请联系作者。
原文链接:bugstack.blog.csdn.net/article/details/115871376
