网页版计算器
小傅哥 发表于 2021/04/24 02:06:02 2021/04/24
【摘要】 html   <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta h...
html
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gb2312" />
<title>计算器</title>
<link type="text/css" rel="stylesheet" href="index.css" />
<script type="text/javascript" language="javascript">
 var Pd = new Boolean();
 //获取点击按钮后,按钮上的信息
 function getButtonValue(eve){
     var textValue = document.getElementById("textId");
  if(Pd){
   if(textValue.value!="+"||textValue.value!="-"||textValue.value!="*"||textValue.value!="/"){
    textValue.value = "";
    textValue.value += eve.value;
    Pd = false;
   }else{
  }else{
 //点击计算按钮后对串进行求值
 function addStr(){
     var strAdd = "";//把串进行组合
  strAdd = textValue.value;
  textValue.value = sumStr(textValue.value);
  strAdd += "="+textValue.value;
  saveHistory(strAdd);
  Pd = true;
 //对批处理进行处理
 function batchStr(){
  var strAdd = document.getElementById("textareaLeftId").value;
  var strGroup = "";//把串进行组合
  var strSum = "";//接收返回结果
  while(strAdd.lastIndexOf("\r\n")!=-1){
      var subString = strAdd;
   subString = strAdd.substring(0,strAdd.indexOf("\r\n"));
   strAdd = strAdd.substring(strAdd.indexOf("\r\n")+1);
   strGroup = subString;
   strSum = sumStr(subString);
   strGroup +="="+strSum;
   saveHistory(strGroup);
 //进行倒数运算
 function daoAdd(eve){
  var strSave = "";
  var str = document.getElementById("textId");
  strSave = str.value+"倒数";
  str.value = 1/parseFloat(str.value);
  saveHistory(strSave+str.value);
 //进行开方运算
 function doSqrt(eve){
     var strSave = "";
  strSave = str.value+"开方";
  str.value = Math.sqrt(parseFloat(str.value));
  saveHistory(strSave + str.value);
 //进行立方运算
 function doPing(eve){
  var strSave = "";
  strSave = str.value+"立方";
  str.value = parseFloat(str.value)*parseFloat(str.value)*parseFloat(str.value);
 //进行混合运算(嵌套递归)
 function sumStr(str){
  //判读加号
  if(str.indexOf("+")>=0){
   var str1= str.substring(0,str.lastIndexOf("+"));
   var str2= str.substring(str.lastIndexOf("+")+1);
   if(str1.indexOf("+")>0 ||str1.indexOf("-")>0 ||str1.indexOf("*")>0 ||str1.indexOf("/")>0){
    str1=sumStr(str1);
   if(str2.indexOf("+")>0 ||str2.indexOf("-")>0 ||str2.indexOf("*")>0 ||str2.indexOf("/")>0){
    str2=sumStr(str2);
   return ""+(parseFloat(str1)+parseFloat(str2));
  //判读减号
  if(str.indexOf("-")>=0){
   var str1= str.substring(0,str.lastIndexOf("-"));
   var str2= str.substring(str.lastIndexOf("-")+1);
    str1=sumStr(str1);
    str2=sumStr(str2);
   return ""+(parseFloat(str1)-parseFloat(str2));
  //判读乘号
  if(str.indexOf("*")>=0){
   var str1= str.substring(0,str.lastIndexOf("*"));
   var str2= str.substring(str.lastIndexOf("*")+1);
    str1=sumStr(str1);
    str2=sumStr(str2);
   return ""+(parseFloat(str1)*parseFloat(str2));
  //判断除号
  if(str.indexOf("/")>=0){
   var str1= str.substring(0,str.lastIndexOf("/"));
   var str2= str.substring(str.lastIndexOf("/")+1);
    str1=sumStr(str1);
    str2=sumStr(str2);
   return ""+(parseFloat(str1)/parseFloat(str2));
  //最后把结果返回
  return str;
 //把计算结果保存历史
 function saveHistory(str){
  var saveStr = document.getElementById("textareaRightId");
  saveStr.value +=str+"\r\n";
  saveStr.value +="----------";
 //清空历史
 function deletHistory(){
  saveStr.value ="";
 //批清除
 function deletBatch(){
  var saveStr = document.getElementById("textareaLeftId");
  saveStr.value ="";
 //清屏
 function deletText(){
   textValue.value ="";
 //退格
 function deletLast(){
   textValue.value =textValue.value.substring(0,textValue.value.length - 1);
 //帮助
 function helpUser(){
 window.alert("本计算机和普通计算器最大的区别在于,可以进行批处理计算。你可以把您要算的式子放到批处理下,之后点批处理就可以了!\r\n式子格式"+
 "1+2*3之后回车输入下一个式子。现在点击确定之后,点击批处理试试吧!记得回车哦!(另外本计算器下没有显示的计算符号一律不支持计算!)");
  saveStr.value ="1+2*3\r\n2+3*6-8\r\n2+6+9+8+5\r\n";
 //作者介绍
 function author(){
  window.alert("作者很低调,木有介绍!");
</script>
</head>
<body>
 <div class="divFace">
  <div class="inFaceTop">
  <img src="top.png" />
  </div>
  <div class="inFaceLeft">
   <textarea class="textareaFace" id="textareaLeftId">  </textarea>
  </div>
  <div class="counterFace">
   <table background="计算器背景 拷贝.jpg">
   <tr align="center"><td colspan="5"><input type="text" class="textFace"  id="textId" maxlength="20" disabled="false"/></td></tr>
   <tr align="center">
    <td><input type="button"  value="批处理" οnclick="batchStr()"/></td>
    <td><input type="button"  value="批清除" οnclick="deletBatch()"/></td>
    <td><input type="button"  value="清历史" οnclick="deletHistory()"/></td>
    <td><input type="button"  value="清屏" οnclick="deletText()"/></td>
    <td><input type="button"  value="退格" οnclick="deletLast()"/></td>
   </tr>
   <tr align="center">
    <td><input type="button"  value="7" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="8" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="9" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="/" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="1/x" οnclick="daoAdd(this)"/></td>
   </tr>
   <tr align="center">
    <td><input type="button"  value="4" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="5" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="6" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="*" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="n3" οnclick="doPing(this)"/></td>
   </tr>
   <tr align="center">
    <td><input type="button"  value="1" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="2" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="3" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="-" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="√" οnclick="doSqrt(this)"/></td>
   </tr>
   <tr align="center">
    <td><input type="button"  value="0" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="00" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="." οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="+" οnclick="getButtonValue(this)"/></td>
    <td><input type="button"  value="=" οnclick="addStr()"/></td>
   </tr>
   </table>
  </div>
  <div class="inFaceRight">
   <textarea class="textareaFace" id="textareaRightId"></textarea>
  </div>
 </div>
 <div class="helpRight">
 <table>
  <tr><td><input type="button" value="帮助"  οnclick="helpUser()"/></td></tr>
  <tr><td><input type="button" value="作者" οnclick="author()"/></td></tr>
 </table>
 </div>
</body>
</html>
css
/* CSS Document */
 margin-top:0px;
 body{
 background-image:url(12b0000O230-16050[1].jpg);
 /*整个页面的布局*/
 .divFace{
 width:800px;
 height:437px;
 margin:0 auto;
 margin-top:50px;
 position:absolute;
 margin-left:300px;
 /*div里面的top布局*/
 .inFaceTop{
 width:800px;
 height:100px;
 /*border-bottom:1px #333333 solid;*/
 /*计算器的布局*/
 .counterFace{
 width:500px;
 border-top:0px;
 border-bottom:0px;
 margin:0 auto;
 float:left;
 .counterFace table{
 width:495px;
 height:337px;
 margin-left:5px;
 /*显示框属性控制*/
 .textFace{
 width:470px;
 height:50px;
 margin:0 auto;
 margin-top:0px;
 font-size:45px;
 background:transparent;
 /*用于计算器左面区域,用于显示历史计算过程*/
 .inFaceLeft{
 width:148px;
 height:334px;
 float:left;
 /*在div表情中加入一个文本框,用于显示历史数据*/
 .textareaFace{
 width:148px;
 height:330px;
 font-size:20px;
 background:url(left.jpg);
 font-family:"楷体_GB2312";
 font-size:24px;
 .inFaceRight{
 width:148px;
 height:334px;
 float:right;
 margin-left:647px;
 position:absolute;
 input{
 width:80px;
 height:50px;
 font-size:18px;
 font-family:"宋体";
 font-style:inherit;
 border:1px solid #FFFFFF;
 /*靠在右面的,用于写帮助信息的*/
 .helpRight{
 position:absolute;
 margin-top:50px;
文章来源: bugstack.blog.csdn.net,作者:小傅哥,版权归原作者所有,如需转载,请联系作者。
原文链接:bugstack.blog.csdn.net/article/details/7766895
