leetcode85. 最大矩形
兔老大 发表于 2021/04/23 00:56:35 2021/04/23
【摘要】 给定一个仅包含 0 和 1 的二维二进制矩阵,找出只包含 1 的最大矩形,并返回其面积。 示例: 输入: [   ["1","0","1","0","0"],   ["1","0","1","1","1"],   ["1","1","1","1","1"],   ["1","0","0","1","0"] ] 输出: 6 ...
示例:
输入:
输出: 6
和leetcode84没什么区别,就是一行一行更新出“高度”,一行一行的跑一遍单调栈即可。
  1. class Solution {
  2. public int leetcode84(int[] heights) {
  3. Stack < Integer > stack = new Stack < > ();
  4. stack.push(-1);
  5. int maxarea = 0;
  6. for (int i = 0; i < heights.length; ++i) {
  7. while (stack.peek() != -1 && heights[stack.peek()] >= heights[i])
  8. maxarea = Math.max(maxarea, heights[stack.pop()] * (i - stack.peek() - 1));
  9. stack.push(i);
  10. }
  11. while (stack.peek() != -1)
  12. maxarea = Math.max(maxarea, heights[stack.pop()] * (heights.length - stack.peek() -1));
  13. return maxarea;
  14. }
  15. public int maximalRectangle(char[][] matrix) {
  16. if (matrix.length == 0) return 0;
  17. int maxarea = 0;
  18. int[] dp = new int[matrix[0].length];
  19. for(int i = 0; i < matrix.length; i++) {
  20. for(int j = 0; j < matrix[0].length; j++) {
  21. dp[j] = matrix[i][j] == '1' ? dp[j] + 1 : 0;
  22. }
  23. maxarea = Math.max(maxarea, leetcode84(dp));
  24. } return maxarea;
  25. }
  26. }
原文链接:fantianzuo.blog.csdn.net/article/details/104027791
