leetcode709. 转换成小写字母 最秀狼人做法(比狠多一点)
兔老大 发表于 2021/04/23 00:55:03 2021/04/23
【摘要】 实现函数 ToLowerCase(),该函数接收一个字符串参数 str,并将该字符串中的大写字母转换成小写字母,之后返回新的字符串。   示例 1: 输入: "Hello" 输出: "hello" 示例 2: 输入: "here" 输出: "here" 示例 3: 输入: "LOVELY" 输出: "lovely" 一个一个的比着换,狠不狠。 cl...
示例 1:
输入: "Hello"
输出: "hello"
示例 2:
输入: "here"
输出: "here"
示例 3:
输入: "LOVELY"
输出: "lovely"
一个一个的比着换,狠不狠。
  1. class Solution:
  2. def toLowerCase(self, str: str) -> str:
  3. str=str.replace("A","a").replace("B","b").replace("C","c").replace("D","d").replace("E","e").replace("F","f").replace("G","g").replace("H","h").replace("I","i").replace("J","j").replace("K","k").replace("L","l").replace("M","m").replace("N","n").replace("O","o").replace("P","p").replace("Q","q").replace("R","r").replace("S","s").replace("T","t").replace("U","u").replace("V","v").replace("W","w").replace("X","x").replace("Y","y").replace("Z","z")
  4. return str
原文链接:fantianzuo.blog.csdn.net/article/details/107450744
