sql查询实例1(学生表_课程表_成绩表_教师表)
兔老大 发表于 2021/04/21 23:08:52 2021/04/21
【摘要】 表架构 Student(S#,Sname,Sage,Ssex) 学生表  Course(C#,Cname,T#) 课程表  SC(S#,C#,score) 成绩表  Teacher(T#,Tname) 教师表 建表语句  CREATE TABLE student ( s# INT, sname nvarchar(32), ...
表架构
SC(S#,C#,score) 成绩表
建表语句
  1. CREATE TABLE student
  2. (
  3. s# INT,
  4. sname nvarchar(32),
  5. sage INT,
  6. ssex nvarchar(8)
  7. )
  8. CREATE TABLE course
  9. (
  10. c# INT,
  11. cname nvarchar(32),
  12. t# INT
  13. )
  14. CREATE TABLE sc
  15. (
  16. s# INT,
  17. c# INT,
  18. score INT
  19. )
  20. CREATE TABLE teacher
  21. (
  22. t# INT,
  23. tname nvarchar(16)
  24. )
插入测试数据语句
  1. insert into Student select 1,N'刘一',18,N'男' union all
  2. select 2,N'钱二',19,N'女' union all
  3. select 3,N'张三',17,N'男' union all
  4. select 4,N'李四',18,N'女' union all
  5. select 5,N'王五',17,N'男' union all
  6. select 6,N'赵六',19,N'女'
  7. insert into Teacher select 1,N'叶平' union all
  8. select 2,N'贺高' union all
  9. select 3,N'杨艳' union all
  10. select 4,N'周磊'
  11. insert into Course select 1,N'语文',1 union all
  12. select 2,N'数学',2 union all
  13. select 3,N'英语',3 union all
  14. select 4,N'物理',4
  15. insert into SC
  16. select 1,1,56 union all
  17. select 1,2,78 union all
  18. select 1,3,67 union all
  19. select 1,4,58 union all
  20. select 2,1,79 union all
  21. select 2,2,81 union all
  22. select 2,3,92 union all
  23. select 2,4,68 union all
  24. select 3,1,91 union all
  25. select 3,2,47 union all
  26. select 3,3,88 union all
  27. select 3,4,56 union all
  28. select 4,2,88 union all
  29. select 4,3,90 union all
  30. select 4,4,93 union all
  31. select 5,1,46 union all
  32. select 5,3,78 union all
  33. select 5,4,53 union all
  34. select 6,1,35 union all
  35. select 6,2,68 union all
  36. select 6,4,71
问题
  1. 问题:
  2. 1、查询“001”课程比“002”课程成绩高的所有学生的学号;
  3. select a.S# from (select s#,score from SC where C#='001') a,(select s#,score
  4. from SC where C#='002') b
  5. where a.score>b.score and a.s#=b.s#;
  6. 2、查询平均成绩大于60分的同学的学号和平均成绩;
  7. select S#,avg(score)
  8. from sc
  9. group by S# having avg(score) >60;
  10. 3、查询所有同学的学号、姓名、选课数、总成绩;
  11. select Student.S#,Student.Sname,count(SC.C#),sum(score)
  12. from Student left Outer join SC on Student.S#=SC.S#
  13. group by Student.S#,Sname
  14. 4、查询姓“李”的老师的个数;
  15. select count(distinct(Tname))
  16. from Teacher
  17. where Tname like '李%';
  18. 5、查询没学过“叶平”老师课的同学的学号、姓名;
  19. select Student.S#,Student.Sname
  20. from Student
  21. where S# not in (select distinct( SC.S#) from SC,Course,Teacher where SC.C#=Course.C# and Teacher.T#=Course.T# and Teacher.Tname='叶平');
  22. 6、查询学过“001”并且也学过编号“002”课程的同学的学号、姓名;
  23. select Student.S#,Student.Sname from Student,SC where Student.S#=SC.S# and SC.C#='001'and exists( Select * from SC as SC_2 where SC_2.S#=SC.S# and SC_2.C#='002');
  24. 7、查询学过“叶平”老师所教的所有课的同学的学号、姓名;
  25. select S#,Sname
  26. from Student
  27. where S# in (select S# from SC ,Course ,Teacher where SC.C#=Course.C# and Teacher.T#=Course.T# and Teacher.Tname='叶平' group by S# having count(SC.C#)=(select count(C#) from Course,Teacher where Teacher.T#=Course.T# and Tname='叶平'));
  28. 8、查询课程编号“002”的成绩比课程编号“001”课程低的所有同学的学号、姓名;
  29. Select S#,Sname from (select Student.S#,Student.Sname,score ,(select score from SC SC_2 where SC_2.S#=Student.S# and SC_2.C#='002') score2
  30. from Student,SC where Student.S#=SC.S# and C#='001') S_2 where score2 <score;
  31. 9、查询所有课程成绩小于60分的同学的学号、姓名;
  32. select S#,Sname
  33. from Student
  34. where S# not in (select S.S# from Student AS S,SC where S.S#=SC.S# and score>60);
  35. 10、查询没有学全所有课的同学的学号、姓名;
  36. select Student.S#,Student.Sname
  37. from Student,SC
  38. where Student.S#=SC.S# group by Student.S#,Student.Sname having count(C#) <(select count(C#) from Course);
  39. 11、查询至少有一门课与学号为“1001”的同学所学相同的同学的学号和姓名;
  40. select distinct S#,Sname from Student,SC where Student.S#=SC.S# and SC.C# in (select C# from SC where S#='1001');
  41. 12、查询至少学过学号为“001”同学所有一门课的其他同学学号和姓名;
  42. select distinct SC.S#,Sname
  43. from Student,SC
  44. where Student.S#=SC.S# and C# in (select C# from SC where S#='001');
  45. 13、把“SC”表中“叶平”老师教的课的成绩都更改为此课程的平均成绩;
  46. update SC set score=(select avg(SC_2.score)
  47. from SC SC_2
  48. where SC_2.C#=SC.C# ) from Course,Teacher where Course.C#=SC.C# and Course.T#=Teacher.T# and Teacher.Tname='叶平');
  49. 14、查询和“1002”号的同学学习的课程完全相同的其他同学学号和姓名;
  50. select S# from SC where C# in (select C# from SC where S#='1002')
  51. group by S# having count(*)=(select count(*) from SC where S#='1002');
  52. 15、删除学习“叶平”老师课的SC表记录;
  53. Delect SC
  54. from course ,Teacher
  55. where Course.C#=SC.C# and Course.T#= Teacher.T# and Tname='叶平';
  56. 16、向SC表中插入一些记录,这些记录要求符合以下条件:没有上过编号“003”课程的同学学号、2、
  57. 号课的平均成绩;
  58. Insert SC select S#,'002',(Select avg(score)
  59. from SC where C#='002') from Student where S# not in (Select S# from SC where C#='002');
  60. 17、按平均成绩从高到低显示所有学生的“数据库”、“企业管理”、“英语”三门的课程成绩,按如下形式显示: 学生ID,,数据库,企业管理,英语,有效课程数,有效平均分
  61. SELECT S# as 学生ID
  62. ,(SELECT score FROM SC WHERE SC.S#=t.S# AND C#='004') AS 数据库
  63. ,(SELECT score FROM SC WHERE SC.S#=t.S# AND C#='001') AS 企业管理
  64. ,(SELECT score FROM SC WHERE SC.S#=t.S# AND C#='006') AS 英语
  65. ,COUNT(*) AS 有效课程数, AVG(t.score) AS 平均成绩
  66. FROM SC AS t
  67. GROUP BY S#
  68. ORDER BY avg(t.score)
  69. 18、查询各科成绩最高和最低的分:以如下形式显示:课程ID,最高分,最低分
  70. SELECT L.C# As 课程ID,L.score AS 最高分,R.score AS 最低分
  71. FROM SC L ,SC AS R
  72. WHERE L.C# = R.C# and
  73. L.score = (SELECT MAX(IL.score)
  74. FROM SC AS IL,Student AS IM
  75. WHERE L.C# = IL.C# and IM.S#=IL.S#
  76. GROUP BY IL.C#)
  77. AND
  78. R.Score = (SELECT MIN(IR.score)
  79. FROM SC AS IR
  80. WHERE R.C# = IR.C#
  81. GROUP BY IR.C#
  82. );
  83. 自己写的:select c# ,max(score)as 最高分 ,min(score) as 最低分 from dbo.sc group by c#
  84. 19、按各科平均成绩从低到高和及格率的百分数从高到低顺序
  85. SELECT t.C# AS 课程号,max(course.Cname)AS 课程名,isnull(AVG(score),0) AS 平均成绩
  86. ,100 * SUM(CASE WHEN isnull(score,0)>=60 THEN 1 ELSE 0 END)/COUNT(*) AS 及格百分数
  87. FROM SC T,Course
  88. where t.C#=course.C#
  89. GROUP BY t.C#
  90. ORDER BY 100 * SUM(CASE WHEN isnull(score,0)>=60 THEN 1 ELSE 0 END)/COUNT(*) DESC
  91. 20、查询如下课程平均成绩和及格率的百分数(用"1行"显示): 企业管理(001),马克思(002),OO&UML (003),数据库(004)
  92. SELECT SUM(CASE WHEN C# ='001' THEN score ELSE 0 END)/SUM(CASE C# WHEN '001' THEN 1 ELSE 0 END) AS 企业管理平均分
  93. ,100 * SUM(CASE WHEN C# = '001' AND score >= 60 THEN 1 ELSE 0 END)/SUM(CASE WHEN C# = '001' THEN 1 ELSE 0 END) AS 企业管理及格百分数
  94. ,SUM(CASE WHEN C# = '002' THEN score ELSE 0 END)/SUM(CASE C# WHEN '002' THEN 1 ELSE 0 END) AS 马克思平均分
  95. ,100 * SUM(CASE WHEN C# = '002' AND score >= 60 THEN 1 ELSE 0 END)/SUM(CASE WHEN C# = '002' THEN 1 ELSE 0 END) AS 马克思及格百分数
  96. ,SUM(CASE WHEN C# = '003' THEN score ELSE 0 END)/SUM(CASE C# WHEN '003' THEN 1 ELSE 0 END) AS UML平均分
  97. ,100 * SUM(CASE WHEN C# = '003' AND score >= 60 THEN 1 ELSE 0 END)/SUM(CASE WHEN C# = '003' THEN 1 ELSE 0 END) AS UML及格百分数
  98. ,SUM(CASE WHEN C# = '004' THEN score ELSE 0 END)/SUM(CASE C# WHEN '004' THEN 1 ELSE 0 END) AS 数据库平均分
  99. ,100 * SUM(CASE WHEN C# = '004' AND score >= 60 THEN 1 ELSE 0 END)/SUM(CASE WHEN C# = '004' THEN 1 ELSE 0 END) AS 数据库及格百分数
  100. FROM SC
  101. 21、查询不同老师所教不同课程平均分从高到低显示
  102. SELECT max(Z.T#) AS 教师ID,MAX(Z.Tname) AS 教师姓名,C.C# AS 课程ID,MAX(C.Cname) AS 课程名称,AVG(Score) AS 平均成绩
  103. FROM SC AS T,Course AS C ,Teacher AS Z
  104. where T.C#=C.C# and C.T#=Z.T#
  105. GROUP BY C.C#
  106. ORDER BY AVG(Score) DESC
  107. 22、查询如下课程成绩第 3 名到第 6 名的学生成绩单:企业管理(001),马克思(002),UML (003),数据库(004)
  108. [学生ID],[学生姓名],企业管理,马克思,UML,数据库,平均成绩
  109. SELECT DISTINCT top 3
  110. SC.S# As 学生学号,
  111. Student.Sname AS 学生姓名 ,
  112. T1.score AS 企业管理,
  113. T2.score AS 马克思,
  114. T3.score AS UML,
  115. T4.score AS 数据库,
  116. ISNULL(T1.score,0) + ISNULL(T2.score,0) + ISNULL(T3.score,0) + ISNULL(T4.score,0) as 总分
  117. FROM Student,SC LEFT JOIN SC AS T1
  118. ON SC.S# = T1.S# AND T1.C# = '001'
  119. LEFT JOIN SC AS T2
  120. ON SC.S# = T2.S# AND T2.C# = '002'
  121. LEFT JOIN SC AS T3
  122. ON SC.S# = T3.S# AND T3.C# = '003'
  123. LEFT JOIN SC AS T4
  124. ON SC.S# = T4.S# AND T4.C# = '004'
  125. WHERE student.S#=SC.S# and
  126. ISNULL(T1.score,0) + ISNULL(T2.score,0) + ISNULL(T3.score,0) + ISNULL(T4.score,0)
  127. NOT IN
  128. (SELECT
  129. DISTINCT
  130. TOP 15 WITH TIES
  131. ISNULL(T1.score,0) + ISNULL(T2.score,0) + ISNULL(T3.score,0) + ISNULL(T4.score,0)
  132. FROM sc
  133. LEFT JOIN sc AS T1
  134. ON sc.S# = T1.S# AND T1.C# = 'k1'
  135. LEFT JOIN sc AS T2
  136. ON sc.S# = T2.S# AND T2.C# = 'k2'
  137. LEFT JOIN sc AS T3
  138. ON sc.S# = T3.S# AND T3.C# = 'k3'
  139. LEFT JOIN sc AS T4
  140. ON sc.S# = T4.S# AND T4.C# = 'k4'
  141. ORDER BY ISNULL(T1.score,0) + ISNULL(T2.score,0) + ISNULL(T3.score,0) + ISNULL(T4.score,0) DESC);
  142. 23、统计列印各科成绩,各分数段人数:课程ID,课程名称,[100-85],[85-70],[70-60],[ <60]
  143. SELECT SC.C# as 课程ID, Cname as 课程名称
  144. ,SUM(CASE WHEN score BETWEEN 85 AND 100 THEN 1 ELSE 0 END) AS [100 - 85]
  145. ,SUM(CASE WHEN score BETWEEN 70 AND 85 THEN 1 ELSE 0 END) AS [85 - 70]
  146. ,SUM(CASE WHEN score BETWEEN 60 AND 70 THEN 1 ELSE 0 END) AS [70 - 60]
  147. ,SUM(CASE WHEN score < 60 THEN 1 ELSE 0 END) AS [60 -]
  148. FROM SC,Course
  149. where SC.C#=Course.C#
  150. GROUP BY SC.C#,Cname;
  151. 24、查询学生平均成绩及其名次
  152. SELECT 1+(SELECT COUNT( distinct 平均成绩)
  153. FROM (SELECT S#,AVG(score) AS 平均成绩
  154. FROM SC
  155. GROUP BY S#
  156. ) AS T1
  157. WHERE 平均成绩 > T2.平均成绩) as 名次,
  158. S# as 学生学号,平均成绩
  159. FROM (SELECT S#,AVG(score) 平均成绩
  160. FROM SC
  161. GROUP BY S#
  162. ) AS T2
  163. ORDER BY 平均成绩 desc;
  164. 25、查询各科成绩前三名的记录:(不考虑成绩并列情况)
  165. SELECT t1.S# as 学生ID,t1.C# as 课程ID,Score as 分数
  166. FROM SC t1
  167. WHERE score IN (SELECT TOP 3 score
  168. FROM SC
  169. WHERE t1.C#= C#
  170. ORDER BY score DESC
  171. )
  172. ORDER BY t1.C#;
  173. 26、查询每门课程被选修的学生数
  174. select c#,count(S#) from sc group by C#;
  175. 27、查询出只选修了一门课程的全部学生的学号和姓名
  176. select SC.S#,Student.Sname,count(C#) AS 选课数
  177. from SC ,Student
  178. where SC.S#=Student.S# group by SC.S# ,Student.Sname having count(C#)=1;
  179. 28、查询男生、女生人数
  180. Select count(Ssex) as 男生人数 from Student group by Ssex having Ssex='男';
  181. Select count(Ssex) as 女生人数 from Student group by Ssex having Ssex='女';
  182. 29、查询姓“张”的学生名单
  183. SELECT Sname FROM Student WHERE Sname like '张%';
  184. 30、查询同名同性学生名单,并统计同名人数
  185. select Sname,count(*) from Student group by Sname having count(*)>1;;
  186. 31、1981年出生的学生名单(注:Student表中Sage列的类型是datetime)
  187. select Sname, CONVERT(char (11),DATEPART(year,Sage)) as age
  188. from student
  189. where CONVERT(char(11),DATEPART(year,Sage))='1981';
  190. 32、查询每门课程的平均成绩,结果按平均成绩升序排列,平均成绩相同时,按课程号降序排列
  191. Select C#,Avg(score) from SC group by C# order by Avg(score),C# DESC ;
  192. 33、查询平均成绩大于85的所有学生的学号、姓名和平均成绩
  193. select Sname,SC.S# ,avg(score)
  194. from Student,SC
  195. where Student.S#=SC.S# group by SC.S#,Sname having avg(score)>85;
  196. 34、查询课程名称为“数据库”,且分数低于60的学生姓名和分数
  197. Select Sname,isnull(score,0)
  198. from Student,SC,Course
  199. where SC.S#=Student.S# and SC.C#=Course.C# and Course.Cname='数据库'and score <60;
  200. 35、查询所有学生的选课情况;
  201. SELECT SC.S#,SC.C#,Sname,Cname
  202. FROM SC,Student,Course
  203. where SC.S#=Student.S# and SC.C#=Course.C# ;
  204. 36、查询任何一门课程成绩在70分以上的姓名、课程名称和分数;
  205. SELECT distinct student.S#,student.Sname,SC.C#,SC.score
  206. FROM student,Sc
  207. WHERE SC.score>=70 AND SC.S#=student.S#;
  208. 37、查询不及格的课程,并按课程号从大到小排列
  209. select c# from sc where scor e <60 order by C# ;
  210. 38、查询课程编号为003且课程成绩在80分以上的学生的学号和姓名;
  211. select SC.S#,Student.Sname from SC,Student where SC.S#=Student.S# and Score>80 and C#='003';
  212. 39、求选了课程的学生人数
  213. select count(*) from sc;
  214. 40、查询选修“叶平”老师所授课程的学生中,成绩最高的学生姓名及其成绩
  215. select Student.Sname,score
  216. from Student,SC,Course C,Teacher
  217. where Student.S#=SC.S# and SC.C#=C.C# and C.T#=Teacher.T# and Teacher.Tname='叶平' and SC.score=(select max(score)from SC where C#=C.C# );
  218. 41、查询各个课程及相应的选修人数
  219. select count(*) from sc group by C#;
  220. 42、查询不同课程成绩相同的学生的学号、课程号、学生成绩
  221. select distinct A.S#,B.score from SC A ,SC B where A.Score=B.Score and A.C# <>B.C# ;
  222. 43、查询每门功成绩最好的前两名
  223. SELECT t1.S# as 学生ID,t1.C# as 课程ID,Score as 分数
  224. FROM SC t1
  225. WHERE score IN (SELECT TOP 2 score
  226. FROM SC
  227. WHERE t1.C#= C#
  228. ORDER BY score DESC
  229. )
  230. ORDER BY t1.C#;
  231. 44、统计每门课程的学生选修人数(超过10人的课程才统计)。要求输出课程号和选修人数,查询结果按人数降序排列,查询结果按人数降序排列,若人数相同,按课程号升序排列
  232. select C# as 课程号,count(*) as 人数
  233. from sc
  234. group by C#
  235. order by count(*) desc,c#
  236. 45、检索至少选修两门课程的学生学号
  237. select S#
  238. from sc
  239. group by s#
  240. having count(*) > = 2
  241. 46、查询全部学生都选修的课程的课程号和课程名
  242. select C#,Cname
  243. from Course
  244. where C# in (select c# from sc group by c#)
  245. 47、查询没学过“叶平”老师讲授的任一门课程的学生姓名
  246. select Sname from Student where S# not in (select S# from Course,Teacher,SC where Course.T#=Teacher.T# and SC.C#=course.C# and Tname='叶平');
  247. 48、查询两门以上不及格课程的同学的学号及其平均成绩
  248. select S#,avg(isnull(score,0)) from SC where S# in (select S# from SC where score <60 group by S# having count(*)>2)group by S#;
  249. 49、检索“004”课程分数小于60,按分数降序排列的同学学号
  250. select S# from SC where C#='004'and score <60 order by score desc;
  251. 50、删除“002”同学的“001”课程的成绩
  252. delete from Sc where S#='001'and C#='001';
原文链接:fantianzuo.blog.csdn.net/article/details/103430105
