ECS服务器限制某个ip的ssh连接
陈方业 发表于 2021/04/20 09:42:44 2021/04/20
【摘要】 Connection closed by foreign host
使用ECS服务器的时候,偶然有一次发现本地ip使用xshell连不上ECS服务器,抓包发现ECS服务器自动将连接给断开,xshell上报错如下:
Connecting to 127.0.0.1:22...
Connection established.
To escape to local shell, press 'Ctrl+Alt+]'.
Connection closing...Socket close.
Connection closed by foreign host.
Disconnected from remote host(chenfangye) at 09:29:20.
Type `help' to learn how to use Xshell prompt.
[C:\~]$
Reconnecting in 5 seconds. Press any key to exit local shell.
最终发现是/etc/sshd.deny.hostguard上带了本地ip,因此做了限制所以,直接在后台将该文件中的ip删除,重新连接成功。
