leetcode97 交错字符串
兔老大 发表于 2021/04/19 23:11:06 2021/04/19
【摘要】 给定三个字符串 s1, s2, s3, 验证 s3 是否是由 s1 和 s2 交错组成的。 示例 1: 输入: s1 = "aabcc", s2 = "dbbca", s3 = "aadbbcbcac" 输出: true 示例 2: 输入: s1 = "aabcc", s2 = "dbbca", s3...
示例 1:
输出: true
示例 2:
输入: s1 = "aabcc", s2 = "dbbca", s3 = "aadbbbaccc"
输出: false
思路:之前做过,比较简单,dp[i][j]代表s1的i个和s2的j个能不能组成。
对于s3的i+j如何组成,只能:
1)i+j-1已经被i和j-1组成,s2[j]==s3[i+j]
比如:
s1:123 s2 456 s3:12453  6
2)i+j-1已经被i-1和j组成,s1[i]==s3[i+j]
比如:s1:126 s2 453 s3:12453  6
压缩空间后的表现还是不理想,搞不懂为什么。
  1. public class Solution {
  2. public boolean isInterleave(String s1, String s2, String s3) {
  3. int len1=s1.length();
  4. int len2=s2.length();
  5. int len3=s3.length();
  6. if (len3 != len1 + len2) {
  7. return false;
  8. }
  9. boolean dp[] = new boolean[s2.length() + 1];
  10. for (int i = 0; i <= len1; ++i) {
  11. for (int j = 0; j <= len2; ++j) {
  12. if (i == 0 && j == 0) {
  13. dp[j] = true;
  14. } else if (i == 0) {
  15. dp[j] = dp[j - 1] && s2.charAt(j - 1) == s3.charAt(i + j - 1);
  16. } else if (j == 0) {
  17. dp[j] = dp[j] && s1.charAt(i - 1) == s3.charAt(i + j - 1);
  18. } else {
  19. dp[j] = (dp[j] && s1.charAt(i - 1) == s3.charAt(i + j - 1)) || (dp[j - 1] && s2.charAt(j - 1) == s3.charAt(i + j - 1));
  20. }
  21. }
  22. }
  23. return dp[s2.length()];
  24. }
  25. }
原文链接:fantianzuo.blog.csdn.net/article/details/103257370
