leetcode143 重排链表
兔老大 发表于 2021/04/20 00:24:45 2021/04/20
【摘要】 你不能只是单纯的改变节点内部的值,而是需要实际的进行节点交换。 示例 1: 给定链表 1->2->3->4, 重新排列为 1->4->2->3. 示例 2: 给定链表 1->2->3->4->5, 重新排列为 1->5->2->4->3. 思路:分成两个链表,第二个逆置,...
示例 1:
示例 2:
思路:分成两个链表,第二个逆置,然后插入即可。
  1. /**
  2. * Definition for singly-linked list.
  3. * public class ListNode {
  4. * int val;
  5. * ListNode next;
  6. * ListNode(int x) { val = x; }
  7. * }
  8. */
  9. public void reorderList(ListNode head) {
  10. if (head == null || head.next == null || head.next.next == null) {
  11. return;
  12. }
  13. //找中点,链表分成两个
  14. ListNode slow = head;
  15. ListNode fast = head;
  16. while (fast.next != null && fast.next.next != null) {
  17. slow = slow.next;
  18. fast = fast.next.next;
  19. }
  20. ListNode newHead = slow.next;
  21. slow.next = null;
  22. //第二个链表倒置
  23. newHead = reverseList(newHead);
  24. //链表节点依次连接
  25. while (newHead != null) {
  26. ListNode temp = newHead.next;
  27. newHead.next = head.next;
  28. head.next = newHead;
  29. head = newHead.next;
  30. newHead = temp;
  31. }
  32. }
  33. private ListNode reverseList(ListNode head) {
  34. if (head == null) {
  35. return null;
  36. }
  37. ListNode tail = head;
  38. head = head.next;
  39. tail.next = null;
  40. while (head != null) {
  41. ListNode temp = head.next;
  42. head.next = tail;
  43. tail = head;
  44. head = temp;
  45. }
  46. return tail;
  47. }
原文链接:fantianzuo.blog.csdn.net/article/details/103405381
