Elasticsearch Query DSL之Compound queries(复合查询)
丁威 发表于 2021/04/19 22:04:53 2021/04/19
【摘要】 本章开始将介绍Elasticsearch DSL查询语法的复合查询。 复合查询将其他复合查询或叶子查询进行包装,组合它们的结果和分数,以此改变它们的行为,或从查询字句切换到过滤上下文模式。 主要的复合查询包括如下: constant_score querybool querydis_max queryfunction_score queryboosting que...
主要的复合查询包括如下:
  • constant_score query
  • bool query
  • dis_max query
  • function_score query
  • boosting query
1、constant_score query
常量(score)评分查询,该复合查询将忽略文档本身的匹配相关性评分,而是统一返回请求参数的boost。
举例说明:(JAVA示例)
public static void testConstantScoreQuery() {
		RestHighLevelClient client = EsClient.getClient();
		try { SearchRequest searchRequest = new SearchRequest(); searchRequest.indices("twitter"); SearchSourceBuilder sourceBuilder = new SearchSourceBuilder(); sourceBuilder.query( QueryBuilders.constantScoreQuery(QueryBuilders.wildcardQuery("user", "ding*")) .boost(1.5f) ); searchRequest.source(sourceBuilder); SearchResponse result = client.search(searchRequest, RequestOptions.DEFAULT); System.out.println(result);
		} catch (Throwable e) { e.printStackTrace();
		} finally { EsClient.close(client);
返回的结果为:为了对比,左边的结果是QueryBuilders.wildcardQuery(“user”, “ding*”)查询,而右边的是constant_score (复合查询)。
{ { "took":4, "took":2, "timed_out":false, "timed_out":false, "_shards":{ "_shards":{ "total":5, "total":5, "successful":5, "successful":5, "skipped":0, "skipped":0, "failed":0 "failed":0 }, }, "hits":{ "hits":{ "total":1, "total":1, "max_score":0.9808292, "max_score":1.5, "hits":[ "hits":[ { { "_index":"twitter", "_index":"twitter", "_type":"_doc", "_type":"_doc", "_id":"12", "_id":"12", "_score":0.9808292, "_score":1.5, "_source":{ "_source":{ "post_date":"2009-11-18T14:12:12", "post_date":"2009-11-18T14:12:12", "message":"test bulk", "message":"test bulk", "user":"dingw" "user":"dingw" } } } } ] ] } }
  • 26
  • 27
2、bool query
布尔查询。bool query里能包含的主要字句类型如下:
字句类型 描述
must 该字句类型的查询语句,文档必须满足,并对评分产生影响(相关度)
filter 子句(查询)必须出现在匹配的文档中。然而,与must不同的是,查询的分数将被忽略。过滤器子句在过滤器上下文中执行,子句被考虑用于缓存。
should 应该匹配;如果没有must和filter,多个should只需要至少一个匹配即可,该数据可以通过参数minimum_should_match控制,如果包含了must或filter,则should不参与实际过滤,但会参与评分。
must_not 查询条件取反,及匹配到的文档必须不符合must_not的条件。
2.1 过滤上下文(filter context)中查询对相关性(打分)的影响
在过滤上下文环境的查询字句并不会对相关性产生影响,也就是说过滤上下文中的查询字句,返回的score为0。
例如如下查询示例(使用Java编写):
public static void testBoolQuery_filterContext_score() {
		try { SearchRequest searchRequest = new SearchRequest(); searchRequest.indices("twitter"); SearchSourceBuilder sourceBuilder = new SearchSourceBuilder(); sourceBuilder.query( QueryBuilders.boolQuery() .filter(QueryBuilders.termQuery("user", "dingw")) ); searchRequest.source(sourceBuilder); SearchResponse result = client.search(searchRequest, RequestOptions.DEFAULT); System.out.println(result);
其返回的结果,其score都为0,结果如下:
{ "took":4, "timed_out":false, "_shards":{ "total":5, "successful":5, "skipped":0, "failed":0 }, "hits":{ "total":3, "max_score":0, "hits":[ { "_index":"twitter", "_type":"_doc", "_id":"22", "_score":0, "_source":{ "post_date":"2018-10-31T14:12:10", "message":"ab and hell", "user":"dingw" } }, { "_index":"twitter", "_type":"_doc", "_id":"12", "_score":0, "_source":{ "post_date":"2009-11-18T14:12:12", "message":"test bulk", "user":"dingw" } }, { "_index":"twitter", "_type":"_doc", "_id":"11", "_score":0, "_source":{ "post_date":"2009-11-19T14:12:12", "message":"test bulk update", "user":"dingw" } } ] }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
3、dis max query
该查询方式将所有查询字句进行联合查询(union),只需要其中一个条件匹配匹配文档,但在计算相关性时不是将所有条件的匹配度(score)相加,而是使使用评分最高的查询条件的score,如果有指定tie_breaker的话,则为最大score 加上 其他score * tie_breaker。dis max query是实现(match query multi fields best_fields)的核心。每个查询,可以指定其评分因子(权重、boost),dis max query使用示例:
	 * dis max query
	public static void testDisMaxQuery() {
		try { SearchRequest searchRequest = new SearchRequest(); searchRequest.indices("twitter"); SearchSourceBuilder sourceBuilder = new SearchSourceBuilder(); sourceBuilder.query( QueryBuilders.disMaxQuery()
// .tieBreaker(0.1f) .add(QueryBuilders.termQuery("user", "dingw").boost(1.2f)) .add(QueryBuilders.termQuery("message", "bulk")) ); searchRequest.source(sourceBuilder); SearchResponse result = client.search(searchRequest, RequestOptions.DEFAULT); System.out.println(result);
4、function score query(函数分数查询)
待研究。
5、boosting query
boosting query可以用来提升或降低某些查询条件的权重。举例如下:
GET /_search
{ "query": { "boosting" : { "positive" : { // @1 "term" : { "field1" : "value1" } }, "negative" : { // @2 "term" : { "field2" : "value2" } }, "negative_boost" : 0.2 } }
代码@1:积极的作用,提升其权重。
代码@2:负面的影响,希望降低其权重,其权重值通过negative_boost指定。
复合查询就介绍到这里了。
见文如面,我是威哥,热衷于成体系剖析JAVA主流中间件,关注公众号『中间件兴趣圈』,回复专栏可获取成体系专栏导航,回复资料可以获取笔者的学习思维导图。
文章来源: blog.csdn.net,作者:中间件兴趣圈,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/prestigeding/article/details/102297796
