aix nfs expdp报错ORA-27054
snowofsummer 发表于 2021/04/15 07:36:39 2021/04/15
【摘要】 报错信息:Connected to: Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit ProductionWith the Partitioning, Automatic Storage Management, OLAP, Data Miningand Real Application Testing opt...
报错信息:
and Real Application Testing options
ORA-39001: invalid argument value
ORA-39000: bad dump file specification
ORA-31641: unable to create dump file "/export/backup/LT_JCPT_GZL.dmp"
ORA-27054: NFS file system where the file is created or resides is not mounted with correct options
Additional information: 5
Additional information: 18
解决方法:
1,10g数据库设置
alter system set events '10298 trace name context forever,level 32';
2,nfs挂在参数
mount -V nfs -o rw,hard,mointr,tcp,noac,vers=3,timeo=600,rsize=32768,wsize=32768  150.12.40.7:/vol/cyfx    /exp
