2021-04-13:判断二叉树是否是平衡二叉树?
福大大架构师每日一题 发表于 2021/04/13 22:43:36 2021/04/13
【摘要】 2021-04-13:判断二叉树是否是平衡二叉树?福大大 答案2021-04-13:1.左子节点平衡。2.右子节点平衡。3.左右子节点高度差不超过1。采用递归即可。代码用golang编写。代码如下:package mainimport "fmt"func main() { head := &TreeNode{Val: 5} head.Left = &TreeNode{Val: 3...
福大大 答案2021-04-13:
1.左子节点平衡。
2.右子节点平衡。
3.左右子节点高度差不超过1。
采用递归即可。
代码用golang编写。代码如下:
package main
import "fmt"
func main() {
    head.Left = &TreeNode{Val: 3}
    head.Right = &TreeNode{Val: 7}
    head.Left.Left = &TreeNode{Val: 2}
    head.Left.Right = &TreeNode{Val: 4}
    head.Right.Left = &TreeNode{Val: 6}
    head.Right.Right = &TreeNode{Val: 8}
    ret := IsBalanced(head)
    fmt.Println("是否是平衡树:", ret)
//Definition for a binary tree node.
type TreeNode struct {
    Val   int
    Left  *TreeNode
    Right *TreeNode
type Info struct {
    IsBalanced bool
    Height     int
func IsBalanced(head *TreeNode) bool {
    return process(head).IsBalanced
func process(head *TreeNode) *Info {
    if head == nil {
        return &Info{IsBalanced: true}
    leftInfo := process(head.Left)
    //左不平衡
    if !leftInfo.IsBalanced {
        return leftInfo
    rightInfo := process(head.Right)
    //右不平衡
    if !rightInfo.IsBalanced {
        return rightInfo
    //高度差大于1
    if Abs(leftInfo.Height, rightInfo.Height) > 1 {
        return new(Info)
    //通过所有考验
    return &Info{IsBalanced: true, Height: GetMax(leftInfo.Height, rightInfo.Height) + 1}
func GetMax(a int, b int) int {
    if a > b {
        return a
        return b
func Abs(a int, b int) int {
    if a > b {
        return a - b
        return b - a
执行结果如下:
左神java代码
评论
评论(0
