ionic 复选框
MICAR 发表于 2021/04/07 10:49:36 2021/04/07
【摘要】 ionic 复选框(checkbox)与普通的 HTML 复选框没什么区别,以下实例演示了 ionic 复选框 ion-checkbox 的应用。<ion-checkbox ng-model="isChecked">复选框标签</ion-checkbox>实例实例中,会根据复选框是否选中,修改 checked 值,true 为选中, false 为未选中。HTML 代码<ion-header...
实例
HTML 代码
<ion-header-bar class="bar-positive">
  <h1 class="title">复选框</h1>
</ion-header-bar>
<ion-content>
  <div class="list">
    <ion-checkbox ng-repeat="item in devList"
                  ng-model="item.checked"
                  ng-checked="item.checked">
      {{ item.text }}
    </ion-checkbox>
    <div class="item">
      <div ng-bind="devList | json"></div>
    </div>
    <div class="item item-divider">
      Notifications
    </div>
    <ion-checkbox ng-model="pushNotification.checked"
                  ng-change="pushNotificationChange()">
      Push Notifications
    </ion-checkbox>
    <div class="item">
      <div ng-bind="pushNotification | json"></div>
    </div>
    <ion-checkbox ng-model="emailNotification"
                  ng-true-value="'Subscribed'"
                  ng-false-value="'Unubscribed'">
      Newsletter
    </ion-checkbox>
    <div class="item">
      <div ng-bind="emailNotification | json"></div>
    </div>
  </div>
</ion-content>
JavaScript 代码
angular.module('starter', ['ionic'])
.run(function($ionicPlatform) {
$ionicPlatform.ready(function() {
  // Hide the accessory bar by default (remove this to show the accessory bar above the keyboard
  // for form inputs)
  if(window.cordova && window.cordova.plugins.Keyboard) {
    cordova.plugins.Keyboard.hideKeyboardAccessoryBar(true);
  if(window.StatusBar) {
    StatusBar.styleDefault();
.controller( 'actionsheetCtl',['$scope',function($scope){
  $scope.devList = [
      { text: "HTML5", checked: true },
      { text: "CSS3", checked: false },
      { text: "JavaScript", checked: false }
    $scope.pushNotificationChange = function() {
      console.log('Push Notification Change', $scope.pushNotification.checked);
    $scope.pushNotification = { checked: true };
    $scope.emailNotification = 'Subscribed';
css 代码:
body {
  cursor: url('http://www.runoob.com/try/demo_source/finger.png'), auto;
