RL之Q Learning:利用强化学习之Q Learning实现走迷宫—训练智能体走到迷宫(复杂迷宫)的宝藏位置
一个处女座的程序猿 发表于 2021/04/02 03:07:35 2021/04/02
【摘要】 RL之Q Learning:利用强化学习之Q Learning实现走迷宫—训练智能体走到迷宫(复杂迷宫)的宝藏位置     目录 输出结果 设计思路 实现代码 测试记录全过程       输出结果   设计思路       实现代码 from __future__ import print_functionimport num...
目录
输出结果
设计思路
实现代码
测试记录全过程
输出结果
设计思路
实现代码
  1. from __future__ import print_function
  2. import numpy as np
  3. import time
  4. from env import Env
  5. from reprint import output
  6. EPSILON = 0.1
  7. ALPHA = 0.1
  8. GAMMA = 0.9
  9. MAX_STEP = 30
  10. np.random.seed(0)
  11. def epsilon_greedy(Q, state):
  12. if (np.random.uniform() > 1 - EPSILON) or ((Q[state, :] == 0).all()):
  13. action = np.random.randint(0, 4) # 0~3
  14. else:
  15. action = Q[state, :].argmax()
  16. return action
  17. e = Env()
  18. Q = np.zeros((e.state_num, 4))
  19. with output(output_type="list", initial_len=len(e.map), interval=0) as output_list:
  20. for i in range(100):
  21. e = Env()
  22. while (e.is_end is False) and (e.step < MAX_STEP):
  23. action = epsilon_greedy(Q, e.present_state)
  24. state = e.present_state
  25. reward = e.interact(action)
  26. new_state = e.present_state
  27. Q[state, action] = (1 - ALPHA) * Q[state, action] + \
  28. ALPHA * (reward + GAMMA * Q[new_state, :].max())
  29. e.print_map_with_reprint(output_list)
  30. time.sleep(0.1)
  31. for line_num in range(len(e.map)):
  32. if line_num == 0:
  33. output_list[0] = 'Episode:{} Total Step:{}, Total Reward:{}'.format(i, e.step, e.total_reward)
  34. else:
  35. output_list[line_num] = ''
  36. time.sleep(2)
测试记录全过程
  1. 开始
  2. ......... ......... . x . ......... . x . .A x o . ......... . x . .A x o . . . ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . x o . . . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . .A x o . .A . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . . x o . . . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . . x o . .A . ......... ......... . x . .A x o . .A . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . .A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . x o . . . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x A . . A . ......... ......... . x . . x A . . . ......... ......... . x . . x A . . . ......... Episode:0 Total Step:17, Total Reward:100 . x . . x A . . . ......... Episode:0 Total Step:17, Total Reward:100 . x A . . . ......... Episode:0 Total Step:17, Total Reward:100 . . ......... Episode:0 Total Step:17, Total Reward:100 ......... Episode:0 Total Step:17, Total Reward:100 ......... ......... . x . ......... . x . .A x o . ......... . x . .A x o . . . ......... . x . .A x o . . . .........
  3. ……
  4. ......... . A . . x o . . . ......... Episode:2 Total Step:30, Total Reward:-5 . A . . x o . . . ......... Episode:2 Total Step:30, Total Reward:-5 . x o . . . ......... Episode:2 Total Step:30, Total Reward:-5 . . ......... Episode:2 Total Step:30, Total Reward:-5 ......... Episode:2 Total Step:30, Total Reward:-5 [F
  5. ……
  6. ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . xAo . . A . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . x A . . . ......... ......... . x . . x A . . . ......... ......... . x . . x A . . . ......... Episode:98 Total Step:8, Total Reward:100 . x . . x A . . . ......... Episode:98 Total Step:8, Total Reward:100 . x A . . . ......... Episode:98 Total Step:8, Total Reward:100 . . ......... Episode:98 Total Step:8, Total Reward:100 ......... Episode:98 Total Step:8, Total Reward:100 ......... ......... . Ax . ......... . Ax . . x o . ......... . Ax . . x o . . . ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . Ax . . x o . . . ......... ......... . x . . x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . A x o . . . ......... ......... . x . . x o . . . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . Ax o . . A . ......... ......... . x . . Ax o . . . ......... ......... . x . . Ax o . . . ......... ......... . x . . Ax o . . . ......... ......... . x . . Ax o . . . ......... ......... . x . . x o . . . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . x o . . A . ......... ......... . x . . xAo . . A . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . xAo . . . ......... ......... . x . . x A . . . ......... ......... . x . . x A . . . ......... ......... . x . . x A . . . ......... Episode:99 Total Step:11, Total Reward:100 . x . . x A . . . ......... Episode:99 Total Step:11, Total Reward:100 . x A . . . ......... Episode:99 Total Step:11, Total Reward:100 . . ......... Episode:99 Total Step:11, Total Reward:100 ......... Episode:99 Total Step:11, Total Reward:100 Episode:99 Total Step:11, Total Reward:100
文章来源: yunyaniu.blog.csdn.net,作者:一个处女座的程序猿,版权归原作者所有,如需转载,请联系作者。
原文链接:yunyaniu.blog.csdn.net/article/details/83245633
