scrapy_redis和scrapy_splash配合使用的配置
xianyuplus 发表于 2021/03/30 21:36:13 2021/03/30
【摘要】 1. scrapy_redis配置DUPEFILTER_CLASS = “scrapy_redis.dupefilter.RFPDupeFilter” # 指纹生成以及去重类SCHEDULER = “scrapy_redis.scheduler.Scheduler” # 调度器类SCHEDULER_PERSIST = True # 持久化请求队列和指纹集合ITEM_PIPELINES = ...
1. scrapy_redis配置
  • DUPEFILTER_CLASS = “scrapy_redis.dupefilter.RFPDupeFilter” # 指纹生成以及去重类
  • SCHEDULER = “scrapy_redis.scheduler.Scheduler” # 调度器类
  • SCHEDULER_PERSIST = True # 持久化请求队列和指纹集合
  • ITEM_PIPELINES = {‘scrapy_redis.pipelines.RedisPipeline’: 400} # 数据存入redis的管道
  • REDIS_URL = “redis://host:port” # redis的url
2. scrapy_splash配置
SPLASH_URL = 'http://127.0.0.1:8050'
DOWNLOADER_MIDDLEWARES = {
'scrapy_splash.SplashCookiesMiddleware': 723,
'scrapy_splash.SplashMiddleware': 725,
'scrapy.downloadermiddlewares.httpcompression.HttpCompressionMiddleware': 810,
DUPEFILTER_CLASS = 'scrapy_splash.SplashAwareDupeFilter'
HTTPCACHE_STORAGE = 'scrapy_splash.SplashAwareFSCacheStorage'
3. scrapy_redis和scrapy_splash配合使用的配置
3.1 原理
  • scrapy-redis中配置了”DUPEFILTER_CLASS” : “scrapy_redis.dupefilter.RFPDupeFilter”,与scrapy-splash配置的DUPEFILTER_CLASS = ‘scrapy_splash.SplashAwareDupeFilter’ 相冲突!
  • 查看了scrapy_splash.SplashAwareDupeFilter源码后,发现他继承了scrapy.dupefilter.RFPDupeFilter,并重写了request_fingerprint()方法。
  • 比较scrapy.dupefilter.RFPDupeFilter和scrapy_redis.dupefilter.RFPDupeFilter中的request_fingerprint()方法后,发现是一样的,因此重写了一个SplashAwareDupeFilter,继承scrapy_redis.dupefilter.RFPDupeFilter,其他代码不变。
3.2 重写dupefilter去重类,并在settings.py中使用
3.2.1 重写去重类
from __future__ import absolute_import
from copy import deepcopy
from scrapy.utils.request import request_fingerprint
from scrapy.utils.url import canonicalize_url
from scrapy_splash.utils import dict_hash
from scrapy_redis.dupefilter import RFPDupeFilter
def splash_request_fingerprint(request, include_headers=None):
    """ Request fingerprint which takes 'splash' meta key into account """
    fp = request_fingerprint(request, include_headers=include_headers)
    if 'splash' not in request.meta:
        return fp
    splash_options = deepcopy(request.meta['splash'])
    args = splash_options.setdefault('args', {})
    if 'url' in args:
        args['url'] = canonicalize_url(args['url'], keep_fragments=True)
    return dict_hash(splash_options, fp)
class SplashAwareDupeFilter(RFPDupeFilter):
    DupeFilter that takes 'splash' meta key in account.
    It should be used with SplashMiddleware.
    def request_fingerprint(self, request):
        return splash_request_fingerprint(request)
"""以上为重写的去重类,下边为爬虫代码"""
from scrapy_redis.spiders import RedisSpider
from scrapy_splash import SplashRequest
class SplashAndRedisSpider(RedisSpider):
    name = 'splash_and_redis'
    allowed_domains = ['baidu.com']
    # start_urls = ['https://www.baidu.com/s?wd=13161933309']
    redis_key = 'splash_and_redis'
    # lpush splash_and_redis 'https://www.baidu.com'
    # 分布式的起始的url不能使用splash服务!
    # 需要重写dupefilter去重类!
    def parse(self, response):
        yield SplashRequest('https://www.baidu.com/s?wd=13161933309',
                            callback=self.parse_splash,
                            args={'wait': 10}, # 最大超时时间,单位:秒
                            endpoint='render.html') # 使用splash服务的固定参数
    def parse_splash(self, response):
        with open('splash_and_redis.html', 'w') as f:
            f.write(response.body.decode())
3.2.2 scrapy_redis和scrapy_splash配合使用的配置
# 渲染服务的url
# 下载器中间件
# 使用Splash的Http缓存
# 去重过滤器
# DUPEFILTER_CLASS = 'scrapy_splash.SplashAwareDupeFilter'
# DUPEFILTER_CLASS = "scrapy_redis.dupefilter.RFPDupeFilter" # 指纹生成以及去重类
DUPEFILTER_CLASS = 'test_splash.spiders.splash_and_redis.SplashAwareDupeFilter' # 混合去重类的位置
SCHEDULER = "scrapy_redis.scheduler.Scheduler" # 调度器类
SCHEDULER_PERSIST = True # 持久化请求队列和指纹集合, scrapy_redis和scrapy_splash混用使用splash的DupeFilter!
ITEM_PIPELINES = {'scrapy_redis.pipelines.RedisPipeline': 400} # 数据存入redis的管道
REDIS_URL = "redis://127.0.0.1:6379" # redis的url
注意:
  • scrapy_redis 分布式爬虫在业务逻辑结束后并不能够自动退出
  • 重写的 dupefilter 去重类可以自定义位置,也须在配置文件中写入相应的路径
评论(0
