数据结构——链队列
ruochen 发表于 2021/03/28 01:14:32 2021/03/28
【摘要】 链队列 空队列 元素x入队列 元素y入队列 元素x出队列 C++代码实现 /*------链队列基本操作-------*/ /* front指针指向头结点(第一个结点的前一个) rear指针指向最后一个结点 */ #include<iostream> #include<stdlib.h> using namespace std; ...
链队列
在这里插入图片描述空队列
元素x入队列
元素y入队列
元素x出队列
C++代码实现
rear指针指向最后一个结点
#include<iostream>
#include<stdlib.h>
#define OK 1
#define ERROR -1
#define OVERFLOW -2
typedef int Status;
typedef int QElemType;
#define MAXSIZE 100
typedef struct Qnode {
	QElemType data;
	struct Qnode* next;
}Qnode, * QueuePtr;
typedef struct {
	QueuePtr front;
	QueuePtr rear;
}LinkQueue;
Status InitLQueue(LinkQueue& Q) {
	Q.front = new Qnode;
	if (!Q.front) exit(OVERFLOW);
	Q.rear = Q.front;
	Q.front->next = NULL;
	return OK;
// 判断链队列是否为空
bool LQueueEmpty(LinkQueue Q) {
	return (Q.front == Q.rear);
// 入队
Status PushLQueue(LinkQueue& Q, QElemType e) {
	QueuePtr q;
	q = new Qnode;
	if (!q)  exit(OVERFLOW);
	q->data = e;
	q->next = NULL;
	Q.rear->next = q;
	Q.rear = q;
	return OK;
// 出队
Status PopLQueue(LinkQueue& Q, QElemType& e) {
	QueuePtr q;
	if(LQueueEmpty(Q)) return ERROR;
	q = Q.front->next;
	e = q->data;
	Q.front->next = q->next;
	if (Q.rear == q) Q.rear = Q.front;
	delete q;
	return OK;
// 销毁链队列
Status DestroyQueue(LinkQueue& Q) {
	while (Q.front) {
		Q.rear = Q.front->next;
		delete Q.front;
		Q.front = Q.rear;
	return OK;
// 获取队头元素
Status GetHead(LinkQueue Q, QElemType& e) {
	if (LQueueEmpty(Q)) return ERROR;
	e = Q.front->next->data;
	return OK;
// 创建链队列
void CreateLQueue(LinkQueue& Q, int m) {
	QElemType e;
	for (int i = 1; i <= m; i++) {
		cout << "请输入第" << i << "个元素: ";
		cin >> e;
		PushLQueue(Q, e);
// 输出链队列
void OutPut(LinkQueue Q) {
	QueuePtr q;
	q = new Qnode;
	q = Q.front->next;
	while (q) {
		cout << q->data << " ";
		q = q->next;
	cout << endl;
int main()
	// 测试代码
	LinkQueue Q;
	int m;
	QElemType e;
	InitLQueue(Q);
	cout << "请输入链队列的长度: ";
	cin >> m;
	CreateLQueue(Q, m);
	cout << "链队列元素为: ";
	OutPut(Q);
	GetHead(Q, e);
	cout << "队头元素为: " << e << endl;
	cout << "请输入入队元素: ";
	cin >> e;
	PushLQueue(Q, e);
	cout << "链队列元素为: ";
	OutPut(Q);
	PopLQueue(Q, e);
	cout << "出列元素为: " << e << endl;
	cout << "链队列元素为: ";
	OutPut(Q);
	return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
请输入链队列的长度: 3
请输入第1个元素: 1
请输入第2个元素: 2
请输入第3个元素: 3
链队列元素为: 1 2 3
队头元素为: 1
请输入入队元素: 4
链队列元素为: 1 2 3 4
出队元素为: 1
链队列元素为: 2 3 4
文章来源: ruochen.blog.csdn.net,作者:若尘,版权归原作者所有,如需转载,请联系作者。
原文链接:ruochen.blog.csdn.net/article/details/102903454
