67 - 用多线程从网上下载图像文件
ruochen 发表于 2021/03/28 01:07:42 2021/03/28
【摘要】 在urls.txt 文件中包含了若干个图像url,一行一个url,请使用多线程下载这些图像文件,并按url出现的顺序保存为 0.jpg、1.jpg、2.jpg,以此类推 urls.txt https://photo.16pic.com/00/26/41/16pic_2641402_b.jpg https://photo.16pic.com/00/21/52/16pi...
urls.txt
https://photo.16pic.com/00/21/52/16pic_2152258_b.jpg
https://photo.16pic.com/00/44/47/16pic_4447412_b.jpg
https://photo.16pic.com/00/20/47/16pic_2047443_b.jpg
from urllib3 import *
import threading
import os
http = PoolManager()
disable_warnings()
f = open('./files/urls.txt', 'r')
urlList = []
while True: url = f.readline() if url == '': break urlList.append(url.strip())
f.close()
# print(urlList)
class DownloadThread(threading.Thread): def __init__(self, func, args): super().__init__(target=func, args=args) def download(filename, url): response = http.request('GET', url) f = open(filename, 'wb') f.write(response.data) f.close print('<', url, '>', '下载完成') root = './files/img'
if not os.path.exists(root): os.makedirs(root) for i in range(len(urlList)): filename = root + '/' + str(i) + '.jpg' thread = DownloadThread(download, (filename, urlList[i])) thread.start()
< https://photo.16pic.com/00/20/47/16pic_2047443_b.jpg > 下载完成
< https://photo.16pic.com/00/26/41/16pic_2641402_b.jpg > 下载完成
< https://photo.16pic.com/00/21/52/16pic_2152258_b.jpg > 下载完成
< https://photo.16pic.com/00/44/47/16pic_4447412_b.jpg > 下载完成
68 - 自定义异常类
文章来源: ruochen.blog.csdn.net,作者:若尘,版权归原作者所有,如需转载,请联系作者。
原文链接:ruochen.blog.csdn.net/article/details/104885859
评论(0
