统计推荐模块
bigdata张凯翔 发表于 2021/03/27 23:14:21 2021/03/27
【摘要】 package com.zkx.statistics import java.text.SimpleDateFormat import java.util.Date import org.apache.spark.SparkConf import org.apache.spark.sql.{DataFrame, SparkSession} import org.apache...
import org.apache.spark.sql.execution.streaming.FileStreamSource.Timestamp
case class Rating(userId:Int,productId:Int,score:Double,timestamp: Int)
case class MongoConfig(uri:String,db:String)
object StatisticsRecommemder {
  //定义mongodb中存储的表名
  val MONGODB_RATING_COLLECTION = "Rating" val RATE_MORE_PRODUCTS = "RateMoreProducts"
  val RATE_MORE_RECENTLY_PRODUCTS = "RateMoreRecentlyProducts" val AVERAGE_PRODUCTS = "AverageProducts" def main(args: Array[String]): Unit = { val config = Map( "spark.cores" -> "local[1]", "mongo.uri" -> "mongodb://localhost:27017/recommender", "mongo.db" -> "recommender" ) //创建一个spark config val sparkConf = new SparkConf().setMaster(config("spark.cores")).setAppName("StatisticsRecommender") //创建spark session val spark = SparkSession.builder().config(sparkConf).getOrCreate() import spark.implicits._ implicit val mongoConfig = MongoConfig(config("mongo.uri"), config("mongo.db")) // 加载数据 val ratingDF = spark.read .option("uri", mongoConfig.uri) .option("collection", MONGODB_RATING_COLLECTION) .format("com.mongodb.spark.sql") .load() .as[Rating] .toDF() //创建一张叫ratings的临时表 ratingDF.createOrReplaceTempView("ratings") //TODO:用spark sql 去做不同的统计推荐 //1.历史热门商品,按照评分个数统计,productId,count val rateMoreProductsDF = spark.sql("select productId,count(productId) as count from ratings group by productId order by count desc") storeDFInMongoDB(rateMoreProductsDF, RATE_MORE_PRODUCTS) //2.近期热门商品,把时间戳转换成yyyyMM格式进行评分个数统计,最终得到productId,count,yearmonth //创建一个日期格式工具 val simpleDateFormat = new SimpleDateFormat("yyyyMM") //注册UDF,将timestamp转化为年月格式yyyyMM spark.udf.register("changeDate", (x: Int) => simpleDateFormat.format(new Date(x * 1000L)).toInt) //把原始rating数据转换成想要的结构productId,count,score,yearmonth val ratingOfYearMonthDF = spark.sql("select productId,score,changeDate(timestame) as yearmonth from ratings") ratingOfYearMonthDF.createOrReplaceTempView("ratingOfMonth") val rateMoreRecentlyProductsDF = spark.sql("select productId,count(productId) as count,yearmonth from ratingOfMonth group by yearmonth,productId order by yearmonth desc,count desc") //把df保存到mongodb storeDFInMongoDB(rateMoreRecentlyProductsDF, RATE_MORE_RECENTLY_PRODUCTS) //3.优质商品统计,商品的平均分 productId,avg val averageProductsDF = spark.sql("select productId,avg(score) as avg from ratings group by productId order by avg desc") storeDFInMongoDB(averageProductsDF,AVERAGE_PRODUCTS) spark.stop()
  } //存到mongodb中的某一张表
  def storeDFInMongoDB(df: DataFrame, collection_name:String)(implicit mongoConfig: MongoConfig): Unit = { df.write .option("uri",mongoConfig.uri) .option("collection",collection_name) .mode("overwrite") .format("com.mongodb.spark.sql") .save()
文章来源: www.jianshu.com,作者:百忍成金的虚竹,版权归原作者所有,如需转载,请联系作者。
原文链接:www.jianshu.com/p/54af6dee5f07
