数据结构——顺序队列
ruochen 发表于 2021/03/25 23:50:06 2021/03/25
【摘要】 队列的顺序 用一维数组base[M] 空队标志: front = rear入队:base[rear++] = x出队:x = base[front++] 存在的问题 front ≠ 0 rear = M时, 假溢出 解决方法——循环队列 实现:利用模运算 入队: base[rear] = x; rear = (rear+1) % M;...
队列的顺序
  • 用一维数组base[M]
  • 空队标志: front = rear
  • 入队:base[rear++] = x
  • 出队:x = base[front++]
存在的问题
front ≠ 0
rear = M时,
假溢出
解决方法——循环队列
  • 实现:利用模运算
    • 入队:
      base[rear] = x;
    • 出队:
      x = base[front];
      front = (front + 1) % M;
C++代码实现
#include<iostream>
#include<stdlib.h>
using namespace std;
#define OK 1
#define ERROR -1
#define OVERFLOW -2
typedef int Status;
typedef int QElemType;
#define MAXSIZE 100  // 最大长度
/*------------静态分配------------*/
//typedef struct {
//	QElemType elem[MAXSIZE];
//	QElemType* rear;  // 队尾指针
//	QElemType* front;  // 队头指针
//	int length;  // 长度
//}SqQueue;
/*------------动态分配------------*/
typedef struct {
	QElemType* elem;  // 动态分配存储空间初始化
	int rear;  // 尾指针
	int front;  // 头指针
}SqQueue;
// 构造空队列
Status InitSqQueue(SqQueue& Q) {
	Q.elem = new QElemType[MAXSIZE];
	if (!Q.elem) exit(OVERFLOW);
	Q.front = Q.rear = 0;
	return OK;
// 队列长度
int QueueLength(SqQueue Q) {
	return(Q.rear - Q.front) % MAXSIZE;
// 判断队列是否为空
bool IsSqQueueEmpty(SqQueue Q) {
	return Q.rear == Q.front;
// 判断队列是否满
bool IsSqQueueFull(SqQueue Q) {
	return (Q.rear + 1) % MAXSIZE == Q.front;
// 入队
Status PushSqQueue(SqQueue& Q, QElemType e) {
	if (IsSqQueueFull(Q)) return ERROR;
	Q.elem[Q.rear] = e;
	Q.rear = (Q.rear + 1) % MAXSIZE;
	return OK;
// 出队
Status PopSqQueue(SqQueue& Q, QElemType &e) {
	if (IsSqQueueEmpty(Q)) return ERROR;
	e = Q.elem[Q.front];
	Q.front = (Q.front + 1) % MAXSIZE;
	return OK;
// 创建队列
void CreatSqQueue(SqQueue& Q, int m) {
	QElemType e;
	for (int i = 1; i <= m; i++) {
		cout << "请输入第" << i << "个元素的值: ";
		cin >> e;
		PushSqQueue(Q, e);
// 输出队列
void OutPut(SqQueue Q) {
	int i;
	i = Q.front;
	while (i != Q.rear) {
		cout << Q.elem[i] << " ";
		i = (i + 1) % MAXSIZE;
	cout << endl;
int main()
	// 测试代码
	SqQueue Q;
	QElemType e;
	int m;
	InitSqQueue(Q);
	cout << "请输入队列的长度: ";
	cin >> m;
	CreatSqQueue(Q, m);
	OutPut(Q);
	cout << "队列的长度为: " << QueueLength(Q) << endl;
	cout << "请输入入队元素: ";
	cin >> e;
	PushSqQueue(Q, e);
	cout << "队列元素为: ";
	OutPut(Q);
	PopSqQueue(Q, e);
	cout << "出队元素为: " << e << endl;
	cout << "队列元素为: ";
	OutPut(Q);
	return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
请输入队列的长度: 3
请输入第1个元素的值: 1
请输入第2个元素的值: 2
请输入第3个元素的值: 3
1 2 3
队列的长度为: 3
请输入入队元素: 4
队列元素为: 1 2 3 4
队列的长度为: 4
出队元素为: 1
队列元素为: 2 3 4
队列的长度为: 3
文章来源: ruochen.blog.csdn.net,作者:若尘,版权归原作者所有,如需转载,请联系作者。
原文链接:ruochen.blog.csdn.net/article/details/102902146
