97 - Flask中如何在Jinjia2模块中使用Python列表
ruochen 发表于 2021/03/25 23:50:18 2021/03/25
【摘要】 如何在Jinjia2模板中使用复杂数据,如Python列表 ''' Jinjia2 ''' from flask import * app = Flask(__name__) class MyClass: def func(self): return 'myclass func' def myfunc(): return 'function' @app.r...
Jinjia2
from flask import *
@app.route('/')
def index(): mydict = {} mydict['type'] = 'dict' mylist = [] mylist.append('list') myclass = MyClass() return render_template('template.txt', mydict=mydict, mylist=myclass, myclass=myclass, myfunc=myfunc)
if __name__ == '__main__': app.run()
 * Serving Flask app "__main__" (lazy loading)
 * Environment: production WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
 * Debug mode: off * Running on http://127.0.0.1:5000/ (Press CTRL+C to quit)
98 - 在Jinjia2模板中如何进行条件控制
文章来源: ruochen.blog.csdn.net,作者:若尘,版权归原作者所有,如需转载,请联系作者。
原文链接:ruochen.blog.csdn.net/article/details/105287744
评论(0
