Spring boot jpa entity
Nick Qiu 发表于 2021/03/26 01:26:00 2021/03/26
【摘要】 前言 本文介绍如何使用spring boot jpa entity。 开发环境如下: 项目 说明 jdk 1.8 idea 2017-03(已经安装lombok插件) mysql 5.6 推荐使用docker navicat mysql 客户端 操作步骤 新建spring boot项目 使用navicat新建数据库db_example 修改配...
前言
开发环境如下:
项目 说明
jdk 1.8
navicat mysql 客户端
操作步骤
  • 新建spring boot项目
  • 使用navicat新建数据库db_example
  • 修改配置文件./src/main/resources/application.properties
spring.jpa.hibernate.ddl-auto=create
spring.datasource.url=jdbc:mysql://localhost:3306/db_example
spring.datasource.username=root
spring.datasource.password=123456
  • 添加实体类book
package org.nick.bootstart.model;/*
 * @Author : Nick
 * @Description :
 * @Date : Create in 12:18 2018/4/30
import lombok.AllArgsConstructor;
import lombok.Data;
import lombok.Generated;
import lombok.NoArgsConstructor;
import javax.persistence.*;
import java.util.HashSet;
import java.util.Objects;
import java.util.Set;
@Data
@NoArgsConstructor
@AllArgsConstructor
@Entity
public class Book { @Id @GeneratedValue(strategy = GenerationType.AUTO) private long id; private String title; private String isbn; public String publisher; @ManyToMany @JoinTable(name = "author_book", joinColumns = @JoinColumn(name = "book_id"), inverseJoinColumns = @JoinColumn(name = "author_id")) public Set<Author> authors = new HashSet<>(); @Override public boolean equals(Object o) { if (this == o) return true; if (o == null || getClass() != o.getClass()) return false; Book book = (Book) o; return id == book.id && Objects.equals(title, book.title) && Objects.equals(isbn, book.isbn) && Objects.equals(publisher, book.publisher); } @Override public int hashCode() { return Objects.hash(id); } @Override public String toString() { return "Book{" + "id=" + id + ", title='" + title + '\'' + ", isbn='" + isbn + '\'' + ", publisher='" + publisher + '\'' + '}'; }
  • 添加Author
 * @Author : Nick
 * @Description :
 * @Date : Create in 12:36 2018/4/30
import lombok.Data;
@Data
@NoArgsConstructor
@AllArgsConstructor
@Entity
public class Author { @Id @GeneratedValue(strategy = GenerationType.AUTO) private long id; private String firstName; private String lastName; @ManyToMany(mappedBy = "authors") private Set<Book> books = new HashSet<>();
  • 执行程序
  • 打开navicat 查看数据库,发现已经初始化了相关表;
这里spring.jpa.hibernate.ddl-auto可以是none,update,create,create-drop。具体含义如下:
  • none 不改变表结构
  • update 通过entity结构改变数据库结构
  • create 每次都打开的时候新建数据库,关闭的时候删除数据库
  • create-drop 创建数据库,然后在SessionFactory关闭的时候删除数据库;
文章来源: www.jianshu.com,作者:Nick_4438,版权归原作者所有,如需转载,请联系作者。
原文链接:www.jianshu.com/p/caf8cf48a757
