1.安装rabbitmq
Nick Qiu 发表于 2021/03/25 23:36:47 2021/03/25
【摘要】 前言 本文介绍如何安装rabbitmq,安装版本为写该文章时的稳定最新版。 安装步骤 安装erlang CentOS 7中安装Erlang 20.x,新建文件/etc/yum.repos.d/rabbitmq-erlang.repo: # In /etc/yum.repos.d/rabbitmq-erlang.repo [rabbitmq-erlang] name=rabb...
前言
安装步骤
安装erlang
  • CentOS 7中安装Erlang 20.x,新建文件/etc/yum.repos.d/rabbitmq-erlang.repo
[rabbitmq-erlang]
name=rabbitmq-erlang
baseurl=https://dl.bintray.com/rabbitmq/rpm/erlang/20/el/7
gpgcheck=1
gpgkey=https://dl.bintray.com/rabbitmq/Keys/rabbitmq-release-signing-key.asc
repo_gpgcheck=0
enabled=1
  • CentOS 6中安装Erlang 20.x ,新建文件/etc/yum.repos.d/rabbitmq-erlang.repo
[rabbitmq-erlang]
baseurl=https://dl.bintray.com/rabbitmq/rpm/erlang/20/el/6
gpgcheck=1
repo_gpgcheck=0
enabled=1
  • 安装erlang,并验证是否安装成功
yum install erlang
erl # 验证是否安装成功
注: 参考https://github.com/rabbitmq/erlang-rpm
安装rabbitmq-server
  • 下载rabbitmq-server(如果没安装wget可以通过yum install -y wget 安装该软件)
wget https://dl.bintray.com/rabbitmq/all/rabbitmq-server/3.7.6/rabbitmq-server-3.7.6-1.el7.noarch.rpm
  • 安装并启动
yum -y install socat
rpm -ivh rabbitmq-server-3.7.6-1.el7.noarch.rpm
service rabbitmq-server start # centos 6执行该命令
systemctl start rabbitmq-server.service # centos 7执行该命令
  • 执行开机启动
chkconfig rabbitmq-server on # centos 6执行该命令
systemctl enable rabbitmq-server.service # centos 7执行该命令
  • 编辑配置文件允许guest用户登录(注意后面逗号)
cd /etc/rabbitmq/
cp /usr/share/doc/rabbitmq-server-3.7.6/rabbitmq.config.example /etc/rabbitmq/
mv rabbitmq.config.example rabbitmq.config
  • 开启web页面管理工具
[root@bogon rabbitmq]# rabbitmq-plugins enable rabbitmq_management
The following plugins have been configured:
  rabbitmq_management
  rabbitmq_management_agent
  rabbitmq_web_dispatch
Applying plugin configuration to rabbit@bogon...
The following plugins have been enabled:
  rabbitmq_management
started 3 plugins.
  • 重启rabbitmq
service rabbitmq-server restart # centos 6执行该命令
systemctl restart rabbitmq-server.service # centos 7执行该命令
  • 开启防火墙
    • centos 6
    iptables -I INPUT -p tcp --dport 15675 -j ACCEPT
    iptables -I INPUT -p tcp --dport 5672 -j ACCEPT
    service iptables
    • centos 7
    firewall-cmd --zone=public --add-port=15672/tcp --permanent
    firewall-cmd --zone=public --add-port=5672/tcp --permanent
    firewall-cmd --reload
  • 网页访问,验证mq安装成功
http://192.168.1.249:15672
补充说明
  • centos 6 命令
    service rabbitmq-server stop
  • centos 7 命令
    systemctl stop rabbitmq-server.service
文章来源: www.jianshu.com,作者:Nick_4438,版权归原作者所有,如需转载,请联系作者。
原文链接:www.jianshu.com/p/06cd9e37a268
评论(0
