nginx配置https转http&wss转ws
Nick Qiu 发表于 2021/03/25 23:40:43 2021/03/25
【摘要】 前言 安装软件 下载 yum -y install gcc pcre pcre-devel zlib zlib-devel openssl openssl-devel wget http://nginx.org/download/nginx-1.17.5.tar.gz tar -xzvf nginx-1.17.5.tar.gz cd nginx-1.17.5 配置ngi...
前言
安装软件
  • 下载
cd nginx-1.17.5
  • 配置nginx
./configure --prefix=/usr/local/nginx --sbin-path=/usr/bin/nginx --with-http_ssl_module --with-http_realip_module --with-http_sub_module --with-stream --with-http_stub_status_module
./configure --help 可以查看配置项说明
完成之后的配置文件见:/usr/local/nginx/conf/nginx.conf,参数配置说明:https://nginx.org/en/docs/configure.html
  • 编译
make && make install
  • 修改配置文件
#user  nobody;
worker_processes  1;
#error_log  logs/error.log;
#error_log  logs/error.log  notice;
#error_log  logs/error.log  info;
#pid logs/nginx.pid;
events { worker_connections  1024;
http { include mime.types; default_type  application/octet-stream; sendfile on; keepalive_timeout  65; server{ listen 80; server_name domain.com; #告诉浏览器有效期内只准用 https 访问 add_header Strict-Transport-Security max-age=15768000; #永久重定向到 https 站点 return 301 https://$server_name$request_uri; } server { listen 443 ssl; server_name  domain.com; # 需要准备好证书 ssl_certificate /usr/local/nginx/conf/cr/server.pem; ssl_certificate_key /usr/local/nginx/conf/cr/server.key; #ssl_session_cache shared:SSL:1m; ssl_session_timeout  5m; #协议配置 ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE; # 转发到http location / { proxy_pass http://domain.com; } } # wss -> ws server { listen 82 ssl; server_name  domain.com; # 需要准备好证书 ssl_certificate /usr/local/nginx/conf/cr/server.pem; ssl_certificate_key /usr/local/nginx/conf/cr/server.key; #ssl_session_cache shared:SSL:1m; # ssl_session_timeout  5m; #协议配置 # ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_protocols SSLv3 SSLv2 TLSv1 TLSv1.1 TLSv1.2; ssl_session_cache shared:SSL:1m; ssl_session_timeout  10m; ssl_prefer_server_ciphers on; # ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE; # 转发到http location / { # 转发ws地址 proxy_pass http://10.1.1.23:82; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; #由于服务器端源码(建议大家做好大小写匹配)只匹配了"Upgrade"字符串,所以如果这里填"upgrade"服务器端会将这条http请求当成普通的请求,导致websocket握手失败 proxy_set_header Connection "Upgrade"; proxy_set_header Remote_addr $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_read_timeout 600s; } }
  • 重启生效
nginx -s reload
文章来源: www.jianshu.com,作者:Nick_4438,版权归原作者所有,如需转载,请联系作者。
原文链接:www.jianshu.com/p/1a0fbfca160d
