Pandas DataFrame plot 绘制饼状图和柱状图
千江有水千江月 发表于 2021/03/21 16:35:28 2021/03/21
【摘要】 环境信息ModelArtsNotebook - Multi-Engine 2.0 (python3)JupyterLab - Notebook - Conda-python3pandas 1.1.5  Pandas DataFrame plot 绘制饼状图和柱状图import pandas as pdimport numpy as npdf = pd.DataFrame(np.random...
环境信息
  • ModelArts
    • Notebook - Multi-Engine 2.0 (python3)
      • JupyterLab - Notebook - Conda-python3
        • pandas 1.1.5
import pandas as pd
import numpy as np
df = pd.DataFrame(np.random.randint(100,size=(3,1)),columns=['num'])
df
# 饼图
# 显示的小数位数 autopct='%.3f%%'
df.plot(kind="pie",subplots=True,autopct='%.3f%%')
# 柱状图
df.plot(kind="bar")
help
# 选取前半部分,主要看一下 kind ,即可以绘制的图表类型
help(df.plot)
Help on PlotAccessor in module pandas.plotting._core object:
class PlotAccessor(pandas.core.base.PandasObject)
 |  Make plots of Series or DataFrame.
 |  Uses the backend specified by the
 |  option ``plotting.backend``. By default, matplotlib is used.
 |  Parameters
 |  data : Series or DataFrame
 |      The object for which the method is called.
 |  x : label or position, default None
 |      Only used if data is a DataFrame.
 |  y : label, position or list of label, positions, default None
 |      Allows plotting of one column versus another. Only used if data is a
 |      DataFrame.
 |  kind : str
 |      The kind of plot to produce:
 |      - 'line' : line plot (default)
 |      - 'bar' : vertical bar plot
 |      - 'barh' : horizontal bar plot
 |      - 'hist' : histogram
 |      - 'box' : boxplot
 |      - 'kde' : Kernel Density Estimation plot
 |      - 'density' : same as 'kde'
 |      - 'area' : area plot
 |      - 'pie' : pie plot
 |      - 'scatter' : scatter plot
 |      - 'hexbin' : hexbin plot.
备注
  1. 欢迎各位同学一起来交流学习心得^_^
  2. 在线课程、沙箱实验、认证、论坛和直播,其中包含了许多优质的内容,推荐了解与学习。
